Author Topic: Vin/Engine decoded question  (Read 1668 times)
Offline javakm70cuda
« on: November 24, 2010 - 11:38:34 AM »
I been trying to find my build sheet from my car & while googling every different combo of my VIN I found a site that decodes vins. My question is, in the picture attached it shows "V8 383 CID 1-4BBL "B" (High Performance). What does the "B" stand for. Would this "B" be stamped on the block near the head? Example "B383"
My engine block does not have any VIN stamped by the oil pan, or a ID pad on there either. So I assumed the "B" stands for 1966 block. Thanks
Offline dutch
Re: Vin/Engine decoded question
« Reply #1 on: November 24, 2010 - 01:52:14 PM »
no vin in the block usually means the engine was replaced under warranty.
The B blocks were the 350, 361, 383 and 400. Later the RB`s were released (Raised B) 440 426
F would be for 1970
*** Bart ***
Offline Cuda Cody
  • Vancouver, WA
« Reply #2 on: November 24, 2010 - 03:09:43 PM »
An engine without a VIN stamp on the pad should still have the VIN pad.  It would just be left blank and would have the factory machine circles.
« Reply #3 on: November 24, 2010 - 04:20:27 PM »
i don't see a stamp ID pad anywhere near the oil pan. Drivers or passenger side.
Pre 1968 maybe
The numbers on the side of the block are 2468130-4
The ID spot close to the distributor says
B383
10  8  2
R
On the other side of the block by the head is a stamped "L"
My drivers door sticker say 11, 69
« Last Edit: November 24, 2010 - 04:56:36 PM by javakm70cuda »
Offline dutch
« Reply #4 on: November 24, 2010 - 05:56:28 PM »
 `66 383
oct. 8th  2nd. engine built that day
R for regular fuel
*** Bart ***
