mini starter?
Author Topic: mini starter?  (Read 4851 times)
lemonboy69
Re: mini starter?
« Reply #15 on: November 23, 2004 - 04:44:35 AM »
Ok... here's a dumb question while we're on the topic... the mini's will also work with slant 6's right?? I was told yes, but CP, you are GOD here!! :thumbs: :grinyes:
LB
Re: mini starter?
« Reply #16 on: November 23, 2004 - 07:52:01 AM »
Yes LB,
  The mini will work on a slant six.
Plum6Pak
Re: mini starter?
« Reply #17 on: November 23, 2004 - 08:18:33 AM »
Here's a link for a new starter, you can get them from a Dodge dealership too. There is one with a higher torque for a higher price.
http://store.yahoo.com/chucker54/starters.html
Offline MAXcuda
Re: mini starter?
« Reply #18 on: November 23, 2004 - 04:48:54 PM »
ah yes, that is smaller.  thanks 4c.  did you put that in to clear the headers?
Offline 4Cruizn
  • HEMI FISH
Re: mini starter?
« Reply #19 on: November 23, 2004 - 07:39:43 PM »
Actually I learned on the hardtop that this starter was just . . . the better choice  Every MOPAR I have will have one of these starters.  You do need to remove the top plastic connection that mounts over the posts for it to go on the e body.  And I actually had to grind a little on the block and the side of the starter to get it to fit up in there as it is alittle snug.  But once in there . . . . . SHHHAAAWEEEEEEET!
 :beer:
Offline zstalker
Re: mini starter?
« Reply #20 on: January 05, 2005 - 08:37:29 PM »
so do the same mini starters that are on all the magnums a direct bolt-on to a big block?  that will save all sorts of effort bench-pressing that beast with one hand, lining up the steel plate and bolts with the other.
Ah, what's that? Worm's wart! mmm! ...and frog's breath.
Re: mini starter?
« Reply #21 on: January 06, 2005 - 01:17:46 AM »
Yes they do
