Author Topic: 440 to Hemi Crate in '72 Challenger  (Read 5627 times)
Offline rhamson
« on: November 17, 2004 - 05:15:31 PM »
I was reading the tech page and saw that the Hemi requires a different K-frame for a small block to big block swap.  Is the same true for a 426 Hemi to a 440 car.  I have a '72 Challenger that was a 340 car originally and was swapped to a 440 by the former owner. Will I have to change the K-frame again to accomadate the Hemi?
Re: 440 to Hemi Crate in '72 Challenger
« Reply #1 on: November 17, 2004 - 05:20:07 PM »
Welcome
 Yes & no , there is a different K frame for the Hemi  due to the exhaust getting in the same place as the mount But Schumakers  -  www.engine-swaps.com   has a great conversion mount to put the Hemi on the V8 K frame
« Last Edit: November 18, 2004 - 10:36:09 AM by Chryco Psycho »
Offline rhamson
« Reply #2 on: November 17, 2004 - 05:44:08 PM »
Thanks for the information.  I had heard of a mount swapping option but was not sure as to who carried the parts.
I had a '69 Roadrunner I swapped a 318 with a 904 tranny for a 383 with a 727 tranny out of a '69 Coronet and it was the easiest swap I could have found. Even the wires on the firewall plugged in without a hitch.
Thanks again.
Offline 360 'CUDA
« Reply #3 on: November 17, 2004 - 10:26:25 PM »
I read that the new crate HEMI can be had with the engine mount ears like the 440
If that's the case your 318 k-member would work just fine with 440 mounts
you might want to add the plate on the bottom for oil pan protection and way bigger torsion bars :thumbs:
« Reply #4 on: November 18, 2004 - 01:47:40 AM »
I think the crate Hemi with the 4400 mount will have troble fitting exhaust to it
Offline rhamson
« Reply #5 on: November 18, 2004 - 06:56:33 AM »
I logged onto Schumachers' website and they have the mounts I was looking for this application.  They also reccomend the TTI headers with this swap which I was anticipating doing anyway.  My only other concern is with the transmission I want to use.  I plan on using the Keisler 5 speed conversion system as I am converting from an automatic with a slap shift.  I will need to know if the position with these new mounts will change any of the tranny and linkage positions.  Keislers system is based on stock applications.  Any Thoughts?
« Reply #6 on: November 18, 2004 - 10:37:07 AM »
the Schumaker mount put the engine in the stock position
Offline rhamson
« Reply #7 on: November 18, 2004 - 04:36:39 PM »
You have been very helpful and I wish to thank you.  I have one other question if I may indulge.  I will be upgrading all the normal performance goodies such as rear disc brakes on the new Moser 60 axle with a trailing link tortion bar, heavy duty springs in the rear as well as Hemi rated torsion bars on the front, frame connectors and torque boxes on the frame, and I am going to get the 528 Hemi 650 HP crate motor from Indy Heads.
My only problem is with carburetion.  I want to use an electronic fuel injection system that is done on a simpler method than what Indy Head offers. Ie. mapps software and calibration that takes a degree from MIT to interpret.  Accael and Edelbrock offer bolt on E.F.I. but not for the rated HP or the motor I have chosen. I believe that Edelbrocks HP rating is only for up to 450  on a 440. I intend to make this car a dependable street machine but don't want to put up with the dual quad set up offered with the motor. Can I pick your brain one more time?
Thanks again.
Offline onebadhemi
« Reply #8 on: November 18, 2004 - 05:01:30 PM »
Well there are alot of options for your set up but, I would like to caution you on indys crate. :nono:
There are better people out there that build that motor better trust me!
Here are a couple to look at
 http://www.forhemisonly.com/
http://www.moparengineswest.com/
The guy at this site knows his efi so I would shoot him an email with your Q's :thumbs:
Dave :wave:
1970 R/T Challenger
1971 Pro street"HEMI" Challenger
2003 V-10 Ram 2500 Q/C
2006 Charger R/T
« Reply #9 on: November 18, 2004 - 11:33:29 PM »
Megasquirt make s a good EFI system as well
Offline 1973challenger360
« Reply #10 on: November 21, 2004 - 12:28:19 AM »
1969 318 904 roadrunner  :nono:  there were only avalible with a 383 magnum 335hp 4bbl or a 426 hemi 425hp then half way through the year the 440-6bbl, must have been a non numbers car or a Satilite.         how much is indys crate, 622 legend  :tongue: :grinyes: :grinno:
Offline rhamson
« Reply #11 on: November 22, 2004 - 06:45:10 AM »
I have long ago sold the car to somebody who blew the motor and I even think he crushed the car. AAARRRGGGHHH.  I don't know if the motor was original to the car because I wanted to swap the 383 into it as I had made a pretty good deal to get the engine. I guess we will never know.
Check www.indyheads.com to get the latest prices and specs.
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #12 on: November 22, 2004 - 08:57:46 AM »
Sounds like you are traveling a similar road that I am.  My engine is the last thing I am going to build, but I have been doing some research, getting suggestions, and finding the people I would like to get involved with for this undertaking.  I am planning on an EFI Hemi also, and so far the guys at www.moparengineswest.com seem to really know thier stuff and seem to be a good group of guys.  They do have a huge number of orders now and you will have to get on a waiting list though.  When I talked with them in mid September, they weren't taking new orders till Mid December or January 2005.
I also noticed that Indy must have an EFI system available now for crate Hemi's.  Someone had new one for sale on Ebay last week.  I don't know anything about it yet though, but if you are set going with Indy, you might inquire about it.
Plum6Pak
« Reply #13 on: November 22, 2004 - 09:39:39 AM »
 :thumbs:  :iagree:
The http://MoparEnginesWest.com is where I picked up my 500 6Pak Stroker, the guy is very knowlegable and knows his electronics. He builds these for some of the hottest performers around. Just thought I would mention that. I'm sure the above leads others provided are great too!
