Author Topic: Motor Oil Viscosity  (Read 1942 times)
Offline inviolet
Motor Oil Viscosity
« on: November 27, 2010 - 09:05:08 PM »
What's up Guys,,
Just curious, I wanted to take a pool,  What Motor Oil Viscosity/Brand do you guys run in your engines? Also state if you change viscosity in the winter/summer and run a Zinc Additive.
383 Stroker (496) Hydraulic Roller Cam so I don't run a Zinc Additive
Castrol GTX 20w-50 All year round, But I don't do much winter driving.
Offline BIGSHCLUNK
Re: Motor Oil Viscosity
« Reply #1 on: November 27, 2010 - 09:59:06 PM »
Currently running Vavoline racing 20-50 w ZDP. Ive always ran at least 15-40 diesel fleet stuff... and have run straight 50 in really hot weather. I gotta admit I go with the best available for the price when its "stock up" time.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline nqkjw
« Reply #2 on: November 28, 2010 - 11:42:02 AM »
Gulf Western 30 grade diesel oil.
Burnouts are cool but Traction is the Action
Offline vinb
« Reply #3 on: November 28, 2010 - 12:44:28 PM »
Flat Tappet Engines,
Mobil Delvac 1300 15/40w. CI-4 Plus or Motorcraft Super Duty 15/40W
Offline JayBee
« Reply #4 on: November 28, 2010 - 01:43:12 PM »
Castrol GTX 20w50, no zinc additive & no winter driving. It's basically a stock 318 (more or less).
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #5 on: November 28, 2010 - 07:42:23 PM »
it really depends on how the engine was machined , if it is loose you need 20-50w  , if the brg clearances are tight 10-30 or 10-40
Offline sadil340
« Reply #6 on: November 28, 2010 - 09:09:38 PM »
Rotella T 15w-40 diesel with ZDDP additive. I don't drive the car much in the winter and it's in a heated garage so I don't change viscosities seasonally.
« Last Edit: November 28, 2010 - 09:11:21 PM by sadil340 »
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline mojavered
  • Someday!
« Reply #7 on: November 29, 2010 - 12:23:36 AM »
Since you mentioned it, what are tight and loose bearing clearances?
Currently running the Valvoline Racing 20-50 or just the 50 in summer time (100+ in summer time).  I also run a bottle of zinc additive.
Jason
Offline inviolet
« Reply #8 on: November 29, 2010 - 02:26:18 PM »
Anyone run 20w-50 in the winter too? The temp around here is in the 30s-40s F,,,Would 20w-50 cause harm in this type of weather temperature?
« Reply #9 on: November 30, 2010 - 01:50:33 AM »
typically somewhere in the .0022- .0025 on the mains & .002 on the rods is tight
Offline moper
« Reply #10 on: December 01, 2010 - 09:00:18 PM »
Most performance flat tappet builds - 15/40 deisel, pisk your brand. I run Car quest which is valvoline, no additive.
Most high performance flat tappet builds - 20/50 or straight 30 Valvoline racing (has high zinc-"not for street use")
roller cams - 10-30 - any brand is fine.
