Author Topic: Goodmark trunkpan + AMD braces = BAD IDEA!!!  (Read 9274 times)
Offline Sean
    • My Cuda Restore
« on: November 27, 2010 - 10:21:11 PM »
Went to lay out the trunk braces on my trunk pan only to find out that they didn't fit together.  There's no gap at the front part of the of the trunk pan but there's an increasing gap as you look rearward.
Anyone ever get a Goodmark pan to work with AMD braces?
I'm guessing my next step would be to order some Goodmark trunk braces?  Anyone have experience putting Goodmark braces on a Goodmark trunkpan?  Do they fit good?
Any advice on what to do next?
Offline Challenger III
Re: Goodmark trunkpan + AMD braces = BAD IDEA!!!
« Reply #1 on: November 27, 2010 - 10:30:56 PM »
Sean,
How does the pan fit on your frame rails? My factory braces didn't fit my AMD trunk floor perfectly either. I forced them together somewhat with sheetmetal screws, test fitted on the car, then welded. If you have to "modify" the tank braces, I don't think it would hurt anything!
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline 67vertman
  • Member since 9-23-2005
« Reply #2 on: November 27, 2010 - 11:10:57 PM »
I used both AMD trunk pan and braces, and they didn't fit all that well either.  I think no matter what you use, there will be some issues.  But they didn't have the type of gaps you are showing.
Offline Sean
    • My Cuda Restore
« Reply #3 on: November 27, 2010 - 11:23:33 PM »
Mike,
Just got in from the garage.  The trunkpan fits in really nice and matches up to the frame rails well.  I'm thinking I might have to cut the braces to fit right and then reinforce them from the inside as to not interfere with the gas tank.  I'm thinking that it wont have to be to pretty as the tank is going to cover the area that I'd be cutting.  There's just too much of a gap to try to bend them.  I'm seeing about a 3/8 gap.
Thanks for the heads up Ron!  Looks like there's not easy way...  LOL!!!
Sean
**EDIT**
Added a pic with arrows showing where the gap is.   :cheers:
« Last Edit: November 27, 2010 - 11:45:18 PM by Sean »
Offline rallye73
  • Model cars for the big boys!!
« Reply #4 on: November 27, 2010 - 11:57:40 PM »
I think there was a gap on the factory pan also. Maybe somebody with an original trunk pan can chime in. There is a gap in mine also. I used the goodmark 2 piece pan and original braces.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
Offline Sean
    • My Cuda Restore
« Reply #5 on: November 28, 2010 - 12:10:35 AM »
Hey John,
Thanks for the feedback!  The gap starts at the front of the pan and gets bigger as you move towards the rear of the car.  It's not just at that one spot.  I dug out the original braces and they sit on it pretty good, hardly any gap at all.  They just need a lot of cleaning to be good enough to put back on the car.  Not sure what will be more work, cleaning up the old or making the new ones work.
Sean
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #6 on: November 28, 2010 - 06:01:31 AM »
I wouldn`t expect them to fit perfect just laying on each other as there is always some fitting but 3/8" does some like a lot.I wouls try clamping/screwing the pan to the frame rails first and then and see if you can get the pan and braces to clamp together better before you start cutting.If needed just cut a slice in the braces at the kick up and reweld.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 72cudamaan
« Reply #7 on: November 28, 2010 - 10:40:47 AM »
Looks to me like the braces are being held away by the edge just to the left of your picture. Maybe just a lil tweaking there could make the brace sit quite a bit lower.   :dunno:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 344speed
« Reply #8 on: November 28, 2010 - 12:18:11 PM »
Sean, have you tried setting the original ones on there to see if they fit better? If they do fit considerably better it is not that hard to clean them up.
72 Ralley 344SPD
Offline Sean
    • My Cuda Restore
« Reply #9 on: November 28, 2010 - 01:09:39 PM »
Mike,
You're absolutely right.  I think if the braces were a 1/4 to 1/2 inch longer, it wouldn't be a problem.
344speed,
I think cleaning up the old ones may be the way to go.  I set them on the pan and they fit pretty good.
Sean
Offline 383DART
« Reply #10 on: December 01, 2010 - 12:00:45 PM »
I purchased amd trunk floor,roof skin,rear tail light panel, 1/4 panels,trunk floor extensions,& deck lid.everything fit very well for a 72 cuda.
« Reply #11 on: December 01, 2010 - 12:15:18 PM »
  :iagree: If you already have new ones, might as well use 'em. "Adjust" them if needed.  :thumbsup:
Offline rhamson
« Reply #12 on: December 02, 2010 - 08:55:56 AM »
Here are a couple of shots of a '72 Challenger if it helps.  These are original and what they should look like and fit.
Offline rhamson
« Reply #13 on: December 02, 2010 - 08:57:15 AM »
Another shot.
Offline Sean
    • My Cuda Restore
« Reply #14 on: December 02, 2010 - 10:08:58 AM »
Thanks rhamson for the pics!  The braces & pan I got are far from that.
Will take some playing with but I'll get it.
Sean
