Author Topic: Vehicle wheel Dollies  (Read 2726 times)
Offline Fastd
« on: November 28, 2010 - 09:12:34 PM »
Not sure if this is the correct board for this post. But here goes, I have a 1970 Challenger that I hope to start work on soon. I am interested in getting some type of wheel dollies to move the car around in my garage when work begins. I am looking for recommendations on what type of dollies to get. Any input would be appreciated.
Todd
Todd
1970 Dodge Challenger (pro-touring build)
1999 Dodge Durango
2006 Dodge Charger 5.7 Hemi (Wifes)
Offline sadil340
Re: Vehicle wheel Dollies
« Reply #1 on: November 28, 2010 - 09:24:15 PM »
The GoJack dollies allow you to raise the wheels without a jack and are easy to roll around. I bought some cheap ones from Harbor Freight and it's a good thing I only need them to cushion the tires for long term storage (the bottoms are curved) because they don't roll for beans. The GoJacks cost more but are worth it in my view
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline BIGSHCLUNK
« Reply #2 on: November 28, 2010 - 11:32:55 PM »
I got a set of the high dollar harbor ones. But gotem for $29 with a couon from mopar muscle. They seem to be
holding up ok. But only had them since this summer.......
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline sadil340
« Reply #3 on: November 29, 2010 - 01:30:22 PM »
In the interests of full disclosure I should mention that I'm putting a 4200 pound car on a set of Harbor Freight dollies rated at 4000 pounds. Could be why they don't roll so well?  :misbehaving:
3:55 SureGrip
Owned since 1974
« Reply #4 on: November 29, 2010 - 01:51:52 PM »
Are you wanting the dollies that you set your tires in....or ones you can bolt to the body to move the car around when the front/rear suspensions are removed?
Offline Fastd
« Reply #5 on: November 29, 2010 - 07:54:46 PM »
Burdar asked  "Are you wanting the dollies that you set your tires in....or ones you can bolt to the body to move the car around when the front/rear suspensions are removed?"
I am looking for the ones that the tires set in
Todd
Todd
1999 Dodge Durango
Offline BIGSHCLUNK
« Reply #6 on: November 29, 2010 - 10:06:24 PM »
Mine were the expensive (for harbor freight) set. Like $79 0r $89  but Mopar Muscle had a coupon a few issues back for $29!   granted I had to go back 3X before I could get them....
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #7 on: November 29, 2010 - 10:30:03 PM »
I got CudaGuys car on the type biggs has , His car rolls around just fine. But you need a good surface like in your garage .
Offline cudadave72
  • you motorboatin sob!!!
« Reply #8 on: December 04, 2010 - 09:07:20 AM »
I'm looking for the ones that mount to the body after the suspension is removed. Where would I find those??
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
« Reply #9 on: December 04, 2010 - 10:59:54 AM »
Your nearest Harbor Freight should have them. My rotisserie had a few rot out and I bought replacements there.
Offline cudadave72
« Reply #10 on: December 04, 2010 - 01:59:52 PM »
Thank You Sir!! :2thumbs: :cheers:
« Reply #11 on: December 06, 2010 - 09:23:33 AM »
Quote
Make your own.  THat's what I did.  I just bought some steel plate and some square tubing.  I bought some small casters at Harbor Frieght but they didn't work very well.  Now I have 6" casters that I bought at Menards.
Very easy and inexpensive.  The front stands mount to the front bumper mounts and the rears bolt to the front leaf spring mount.
Offline NoMope Greg
« Reply #12 on: December 06, 2010 - 12:27:19 PM »
I bought my Tire Skates from this company:
http://www.accessiblesystems.com/index.php
More expensive than the Harbor Freight wheel dollies, but very high quality.  I had no problem moving my car around the garage and driveway.   :2thumbs:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline CudaNut
  • She's so fine ain't no tellin where the money went
    • CUDANUT.COM
« Reply #13 on: December 14, 2010 - 06:16:56 PM »
Just make them out of square tubing, I will try to post a pic later tonight of some we use in the shop. I made them in about 2-3 hrs counting cutting the steel. I've got about $90 in the whole set of six including the flea market casters I bought...They also have adjustable height to make up for uneven floors. I threaded some blocks and welded them to the side of the tubing then used all thread to make adjustments on height. This allows you to get the body 100% level and keep it that way after you cut off the metal. You would be surprised how bad out of tolerance these bodies were from the factory and how much they "relax" after you cut off stuff... This one was 1/4 out of level on the pass side. If needed you can remove the casters and make metal pads to replace the casters to make it even more rigid or bolt it to a trailer.
« Last Edit: December 14, 2010 - 07:39:07 PM by CudaNut »
"If I had my life to live over again, I'd be a plumber."
  Albert Einstein
