Author Topic: Key Buzzer - 1970 Challenger R/T SE  (Read 2746 times)
Offline sublime r/t se
« on: November 29, 2010 - 07:21:55 PM »
Okay, now that I have fully troubleshot and corrected the warning lights in my upper consolette, I wanna go for something different, the key buzzer.
I know that the last two red wires on the steering column connector run the buzzer.  One appears to be hot, and one appears to go to the buzzer.  When hot is applied to the terminal that goes to the buzzer, the buzzer buzzes, so it must be working.
The question I have is that does the key-in switch simply close the circuit?  It appears that way, vs completing a ground.    If this is the case, I should be able to test the two red wires coming out of the steering column and that circuit should close (no resistance) if the switch works correctly.
If the switch is bad, I assume that the entire ignition switch needs to be replaced.   Not likely worth doing if that is the case, but just wanted to know.
Thanks to all.
1969 Roadrunner Convertible
2006 Chrysler 300C SRT8
2006 Jeep Grand Cherokee SRT8
2001 Ford Mustang GT Convertible
Offline Giveitawack
    • ebay
Re: Key Buzzer - 1970 Challenger R/T SE
« Reply #1 on: November 30, 2010 - 12:37:53 AM »
The buzzer switch closes a circuit. Both red wires run to the switch. One in, one out. The switch is a separete unit and not a part of the ignition switch.
You can replace only the buzzer switch.
« Reply #2 on: November 30, 2010 - 12:48:01 AM »
That is great information.  If the ignition switch does not need to be replaced, does all that stuff have to come out (steering wheel, turn signal switch, blah blah) in order to replace the buzzer switch??
« Reply #3 on: November 30, 2010 - 03:03:39 AM »
Yes the crush can , turn signal switch etc all has to be removed the switch is below the lock plate
« Reply #4 on: November 30, 2010 - 11:48:56 AM »
Thanks mucho for the info.  Hopefully the switch is okay.  If it's not, something else is gonna have to fail before I take all of that stuff apart.
