Author Topic: The absolutely most reliable ignition system?  (Read 5509 times)
Offline priderocks
« on: December 02, 2010 - 12:33:41 AM »
If your life depended on your ignition system and performance was not an issue, what system would you use?
In my opinion, the most reliable (by reliable, I'm talking about one that won't leave you stranded) system would have to be one without the mopar ECU, and preferably the fewer electronics the better. What do you think? My vote is an  original dual-point.
I can remember setting the points on my 69 340 Dart with a flashlight and a matchbook cover. Most reliable car I ever had.
Re: The absolutely most reliable ignition system?
« Reply #1 on: December 02, 2010 - 12:57:17 AM »
Points are reliable
 for servicability I use the Mopar ECU / Chrome box not orange & carry a spare , the GM module may work well too , parts would be simple to get & easily swapped
 anything man made will fail
Offline GoodysGotaCuda
« Reply #2 on: December 02, 2010 - 07:31:47 AM »
I've had my MSD 6A that I bought second hand for about five years now. Never had an ignition hiccup. Certainly would get another box, probably go digital control and not look back  :wave:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Roppa440
« Reply #3 on: December 02, 2010 - 10:36:05 AM »
The GM type HEI chip is far more reliable than all the rest no matter what anyone will tell you. Fit it alongside any electronic distributor and forget it for the life of the car. Use a 12v coil and no ballast resistor. Great spark up to 7000rpm with the good quality aftermarket modules.
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
Offline Cooter
    • christinecarclub.com
« Reply #4 on: December 02, 2010 - 01:23:51 PM »
M  S  D
Run the stock Chrysler distributor and wire it to the MSD box and forget it..The only time MSD gives a problem is usually, when idiots hook it up incorrectly and burn the box up, or the car is welded on with the battery hooked up....
« Last Edit: December 02, 2010 - 01:26:12 PM by Cooter »
Offline Cuda Cody
  • Vancouver, WA
« Reply #5 on: December 02, 2010 - 02:14:02 PM »
Is there any way to get a stock looking electronic distributer?
Offline Roppa440
« Reply #6 on: December 02, 2010 - 03:27:01 PM »
Yes. You can do a points conversion inside a stock distributor. There are kits to do this.
1970 Challenger R/T
Offline Roppa440
« Reply #7 on: December 02, 2010 - 03:29:28 PM »
M  S  D
My backside.
 ;D
I know dozens of people that have had them break. You can also forget about accurate timing.
1970 Challenger R/T
« Reply #8 on: December 02, 2010 - 03:30:17 PM »
using a Mopar dist the only difference is 2 wires instead of one coming out for points
Offline DocMel
« Reply #9 on: December 02, 2010 - 03:55:08 PM »
Chryc
Thanks for the feedback, but your set up maybe a liitle too exotic for me.   Im looking for more more of a "one stop" shop, direct bolt on using my stock intake with no mods, hence the direct bolt on, FAST type set up
Going back to my original post, any input from folks now using the FAST, or other type bolt on EFI kits around the $2000 range is appreciated
Offline moper
« Reply #10 on: December 03, 2010 - 07:33:12 AM »
When my life depends on it I run the factory single point. As in my plow truck, because I am responsible for a shared driveway with a retire woman for a neighbor and if the driveway's not passable you can't reach eitehr of our houses.
That being said, I've had no troubles with MSD or factory ECUs, but the single point will start/run if the battery is almost dead, the others will not.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #11 on: December 03, 2010 - 08:11:45 AM »
One of the few advantages of a '72, at least it has electronic ignition.  :D
Here's a nice little article on electronic ignition conversion: http://www.allpar.com/mopar/nopoints.html
Offline acudanut
« Reply #12 on: December 03, 2010 - 10:49:01 AM »
The Mopar Electronic Ign is the way to go....Gm and Ford only wish they had our systems on their cars...That's where MSD came into play in the first place  :2cents:
Offline priderocks
« Reply #13 on: December 03, 2010 - 11:58:42 AM »
I guess I've been bit too many times by failed mopar ecu's. What systems would also eliminate the ballast resistor?
Offline Roppa440
« Reply #14 on: December 03, 2010 - 12:09:02 PM »
I refer you to my earlier post. The HEI modual. A $25 part for a complete and powerful ignition system.
1970 Challenger R/T
