What do yall mean by bonding? Like JB weld or something? How would that be better than welding? Obviously I have no idea what yall are talking about. I thought everything was welded....
Yes, it those days everything was welded,but bonding is far more superior in this case,because the adhesive not only holds panels together, but serves as a sealer and completely seals the seam eliminating any corrosion at the joint,opposed to welding,cowl is very sensitive area of the car that can trap moisture,on some cars it's absolutely inaccessible ,so using panel bonding adhesive is the smartest way to go,I use it all the time.
SEM,Duramix/3m Automix,Fusor,Norton make great bonding adhesives ,most dual cartridge runs about $30-40,they offer different working time,as some parts take less/more that others to install,thus different curing time.Give it a try sometime,you'd be amazed,no drilling,no welding,no grinding and best of all,NO RUST years down the road
