Author Topic: AM/FM Radio Volume Issues  (Read 1558 times)
Offline VTMopar
« on: December 06, 2010 - 10:15:11 PM »
My AM/FM original radio works - but the volume is very low unless the engine is rev'd up.....   AM comes in quite good - FM is spotty....    Any ideas?
Thanks
VT Mopar
VT MOPAR
Re: AM/FM Radio Volume Issues
« Reply #1 on: December 06, 2010 - 10:26:43 PM »
If I recall correctly FM is more sensitive to antenna ground.
Offline Challenger6pak
« Reply #2 on: December 07, 2010 - 11:37:52 AM »
Could be a voltage problem.  Maybe the tiny amp needs more power. You could run a jump wire dirrectly to the battery to see if the problem goes away.  It is odd.
Offline VTMopar
« Reply #3 on: December 09, 2010 - 09:00:19 PM »
Good ideas..... hopefully one of these will solve it :)
thanks
VT Mopar
VT MOPAR
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #4 on: December 10, 2010 - 03:22:12 AM »
Make sure the speaker wire connectors are on tight and the wires are not frayed or grounding out against each other.
Lightly spraying some WD-40 into the volume control stem can clear up a lot of issues with static when rotating the knob.
Check your antenna wire plug going into the radio for a solid fit.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
