Author Topic: who has gearvendors od?  (Read 4668 times)
Offline one54dodgetruck
« on: December 08, 2010 - 03:58:39 AM »
who has gear vendors od? im getting ready to buy one. the cheepest ive found is for $2695 + $55 for shiping....
does anyone know of a cheeper place?
thanks
andrew
73 challenger rally 340
Re: who has gearvendors od?
« Reply #1 on: December 08, 2010 - 09:19:05 AM »
they are not cheap , I have installed a few of them & they are a good unit
Offline ragtopdodge
« Reply #2 on: December 10, 2010 - 09:35:46 AM »
Man, that's a lot of money.
I think you can get a decent A518 (46RH) for that kind of coin.  Even with a JW Bell to fit a big block.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #3 on: December 10, 2010 - 12:02:16 PM »
the problem with a 518 is the od sucks. it would take alot of money to get a built unit. then change your tranny crossmember because the od unit is to big to fit in the tunnel where the cross member is. i guess the gv unit will bolt right up and just a little massaging is needed and its good for 1200hp so should last forever behind my little 240hp 340. and in another 30yrs and the value of these cars goes up i can pull it off and sell it as an origional car.
andrew
Offline ragtopdodge
« Reply #4 on: December 10, 2010 - 04:30:35 PM »
andrew
you familiar w/this thread?
http://www.cuda-challenger.com/cc/index.php?topic=23678.0
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #5 on: December 10, 2010 - 04:58:34 PM »
Personally I like the 518 option better than the gear vendors, because for one the total cost of a 518 conversion would be less than the price of buying a gear vendor unit and still having a non rebuilt transmission (unless you have your existing transmission rebuilt at the same time, which adds more cost), 2nd if something goes wrong with the 518 compared to the gear vendor parts are a little easier to get since the 518 is a factory transmission compared to an aftermarket addition. You can get a 518 with a lockup converter which acts like another half gear to aid in fuel economy. Granted you do have to make a custom crossmember and slightly modify the transmission case's extra webbing to make it fit but that's it. The install is pretty easy and straight forward.
Check out this link they sell rebuilt 518's and they sell the parts to install one in your car. Do not listen to people that say you cannot use the stock slap stick linkage, because a member on here did it and I think the pictures and details are listed in the thread linked above.
http://www.redrider.us/518_transmission.htm
1996 Dodge Viper GTS Coupe
Offline BIGSHCLUNK
« Reply #6 on: December 10, 2010 - 06:23:03 PM »
I remember it well. But i think his biggest issue was the "split shifting" part (which is fun!!)
Not the actuall OD part.....  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #7 on: December 10, 2010 - 07:18:13 PM »
rebuilding a 727 is a really easy task although mine is in great shape. im looking at a unit that is good for alot more than 240hp so with proper maintenance it should last as long as i do. i dont have the tools to rebuild a 518 i hear the od unit needs a special tools to assymble.
im made this post to find the few with gearvendors and what they think of them
andrew
Offline BIGSHCLUNK
« Reply #8 on: December 10, 2010 - 11:09:32 PM »
I like to do it eventually/ Then take out the 3.23's   :cooldancing:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline 500Stroker
« Reply #9 on: December 11, 2010 - 12:27:35 AM »
I have had my GV for about 6 years now.  Logged over 40K miles on it with no troubles or issues.  I consider it the best upgrade I ever did to the car.  I paid $2100 back then but prices have been rising each year.  I think the price is pretty much fixed no matter who you buy it from.  Try pricing one at  http://coperacingtrans.com/ I heard of a few guys buying from him.
Offline ntstlgl1970
  • T a c o c a t
« Reply #10 on: December 11, 2010 - 02:13:22 AM »
andrew
You will need to buy special tools and have a shop press to rebuild the OD section on a 518, like you said. The gearvendor is a good unit.
Offline EbodyMod
  • Will it ever be finished????
« Reply #11 on: October 23, 2015 - 09:24:09 PM »
 :wavingflag: How much horsepower can this thing handle? my engine will be around 575hp and was planning on 3.55 gears. I don't want to do a 518 upgrade because my 727 already has been built and it has a manual reverse valve body and I plan on using kilduff lightning rods for a shifter.  will this thimg hold up for highway use?
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #12 on: October 23, 2015 - 09:57:39 PM »
GEAR VENDORS offers a 2 year unlimited horsepower warranty that is guaranteed even at the drag strip. Tough to beat!
You won't get that with any 5 speed. My painter put one in his brothers Fastback Barracuda and has one in his old Ram PU.
They love 'em.
The GV cost more than his truck is worth but it just keeps going.
Santa, if you were wondering...
https://www.gearvendors.com/faq.html
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline djw383
« Reply #13 on: October 24, 2015 - 09:38:05 AM »
Take a half hour and watch this: https://youtu.be/SywsCGnoXOU
