Author Topic: Accurate exhaust systems  (Read 3393 times)
Offline John A
« on: December 09, 2010 - 07:40:31 PM »
Has anyone installed an exhaust system from Accurate exhaust Company? Looking to purchase a system for my 74 Barracuda, 360 4 speed car with Doug's headers installed. Thanks John.
Re: Accurate exhaust systems
« Reply #1 on: December 09, 2010 - 07:52:01 PM »
Lots of us have, including me. I really haven't had an issue with them and have used the more than 3 times
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: December 09, 2010 - 08:03:33 PM »
Does Accurate make systems for headers  :dunno: I used them for my 70 440 6 pack cuda project and as far as original look and sound Accurate makes a top notch product. If you want something other than stock (which based on the fact that you have Doug's headers I will assume you do) I am not sure if there is a better choice for your application.
1996 Dodge Viper GTS Coupe
Offline John A
« Reply #3 on: December 09, 2010 - 08:44:58 PM »
How did the system fit? Did you use the mufflers and the resonators? The car is a driver, want it to sound good but not too loud...Thanks  John.
Offline 72hemi
« Reply #4 on: December 09, 2010 - 09:21:33 PM »
I used their complete system as I was doing a stock restoration. Here are some pictures of my system installed. Easiest exhaust system to install, but it should have been since I was using all stock components from the manifolds back.
Offline challengermaniac
« Reply #5 on: December 09, 2010 - 09:31:25 PM »
I used their complete system on my plum crazy TA clone with stock exhaust manifolds.  The system fit 99% well with just a slight angle problem, but for the most part I am very satisfied and it's sounds TERRIFIC!
As noted, you will need to modify them slightly in order to fit up to headers.   Their tech support will get you all the information you need.
« Last Edit: December 09, 2010 - 09:33:23 PM by challengermaniac »
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Offline John A
« Reply #6 on: December 09, 2010 - 09:47:57 PM »
Thanks for the pictures of the exhaust, looks great. John.
Offline sadil340
« Reply #7 on: December 09, 2010 - 09:51:43 PM »
I got the stock Accurate system from the front pipes back and got the front pipes through Year One. The Accurate parts are great, no complaints. The front pipes never fit right and I go through flange gaskets regularly.
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
