Alright, so here's the fun:
The epoxy layer around the clutch field assembly:
First question:
1. If the purpose of the clutch field assembly is to engage the clutch magnetically, I suppose this epoxy layer is to insulate the clutch field assembly from grounding prematurely?
2. if the compressor clutch is NOT engaged (no current to the clutch field assembly), and the bearing the pulley was NOT siezed, it should spin freely and with very little force, because it wouldn't actually be spinning the crankshaft of the compressor, just rolling on the pulley's bearing? If it were engaged, it would take some force to spin because it would be turning over the compressor, but would spin, yes?
And after the clutch seized:
And the crankshaft of the compressor:
Back to my reasoning:
3. If #1 and #2 were true:
3a. it doesn't appear as if the clutch was disengaging when disconnected from the battery because i was turning the pulley while it was disconnected.
3b. more importantly, it looks as if ShelbyDogg's take that its the compressor's fault is inline with the photos, since the crankshaft quite clearly was not turning over.
Am I reading my maintenance manual and these photos correctly?
JF
