Author Topic: fuel tank wire  (Read 779 times)
Offline 7samurai
fuel tank wire
« on: December 12, 2010 - 05:25:17 PM »
installed new rear harness on the cuda.  has fuel tank wire with grommet. cannot figure where it goes through the body as there is no obvious hole. suggestions?
Offline dutch
Re: fuel tank wire
« Reply #1 on: December 12, 2010 - 05:35:57 PM »
where did you pull the old wire from? I`m not sure if all years are the same, but on my 70 there`s a small gutter pressed in the trunkfloor ending in a hole. It`s on the left from the middle, a few inches from where the trunkfloor goes up towards the shocktowers
*** Bart ***
Re: fuel tank wire
« Reply #2 on: December 12, 2010 - 05:36:57 PM »
look at the 7th picture down..just to the left of the spare,
http://www.cuda-challenger.com/cc/index.php?topic=73375.msg748230#msg748230
Offline 7samurai
Re: fuel tank wire
« Reply #3 on: December 12, 2010 - 10:59:01 PM »
started with a shell. new trunk floor patch panels, shaker hood and trunk lid and lots and lots of sanding.  do not have many reference points other than service manuals, lousy "restoration" books and lots of good advice on this site.
Offline Cuda54
Re: fuel tank wire
« Reply #4 on: December 15, 2010 - 11:04:06 PM »
If there is no hole go under by the tank. Look where the sending unit is and drill up threw the floor into the trunk.
