Author Topic: Dome light turn signals  (Read 2500 times)
Offline william43
  • 440 6 pack
« on: December 13, 2010 - 04:31:33 PM »
Dome light stays on, Plus the lelf turn signal works fine,untell i turn the lights on,the lelf turn gos out,and the arrow shows up and stays on and does not blink.Is there someone that could help. Bill
« Last Edit: December 13, 2010 - 04:43:56 PM by william43 »
WD
Offline Challenger6pak
Re: Dome light turn signals
« Reply #1 on: December 13, 2010 - 05:31:33 PM »
I'm guessing a short in your wiring harness.  You will have to get a diagram and trace all the wires until you find the short.
Offline william43
  • 440 6 pack
« Reply #2 on: December 13, 2010 - 05:37:24 PM »
I got a diagram,will look,hope there was a easy way. Thanks Bill
WD
Offline william43
  • 440 6 pack
« Reply #3 on: December 13, 2010 - 05:38:59 PM »
WD
« Reply #4 on: December 13, 2010 - 06:53:00 PM »
It could be that one of the turn signal/parking lamp bulbs, front or rear, has a filament that has broken & welded itself to the other filament creating feedback of power when you turn your parking lamps on. Happened to me once.
As for the dome light you know the panel dimmer switch can turn on the dome light, otherwise I'd check the door jamb switches & their connectors.
Offline william43
  • 440 6 pack
« Reply #5 on: December 13, 2010 - 07:09:05 PM »
Thanks, i check everything,The turn signal works,if the lights are not turn on.
WD
« Reply #6 on: December 14, 2010 - 05:31:36 PM »
you have a poor ground at the turn signal so the power is grounding back through the park light causing the dash light to stay on , make sure the socket & housing are grounded & that will solve the TS problem
 the dome light is different , the yellow wire is grounding somewhere possibly through the dimmer switch creating a ground for the dome light
Offline william43
  • 440 6 pack
« Reply #7 on: December 14, 2010 - 06:08:51 PM »
WD
Offline william43
  • 440 6 pack
« Reply #8 on: December 14, 2010 - 06:11:08 PM »
This sounds dumb,but where do i start,
WD
« Reply #9 on: December 14, 2010 - 06:29:23 PM »
I would start at the socket & housing.
Offline william43
  • 440 6 pack
« Reply #10 on: December 14, 2010 - 06:49:04 PM »
  WILL DO.
WD
« Reply #11 on: December 15, 2010 - 10:44:59 AM »
I have had to use a pin punch to recreate a grond between the socket & housing at times
 start disconnecting the yellow wires at the light switch & door switches until the dome light turns off
