Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Carrier: What do I have?
« previous
next »
Print
Pages: [
1
2
Author
Topic: Carrier: What do I have? (Read 2691 times)
JonS
Jr. Member
on:
December 15, 2010 - 08:41:39 AM »
I posted this in WIW section but this is probably the proper place for it:
Not sure exactly what I have here... There are no obvious casting numbers for IDing. Does anyone know what it is and what it is worth?
It does have a 3.00 stamped on the ID plate at the back. And it looks like a "V" inside of a C shape along the snout (maybe 1/2" tall).
Logged
JonS
Jr. Member
Re: Carrier: What do I have?
Reply #1 on:
December 15, 2010 - 08:41:57 AM »
More
Logged
JonS
Jr. Member
Reply #2 on:
December 15, 2010 - 08:42:14 AM »
More again...
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
December 15, 2010 - 10:51:07 AM »
Well it looks like a race piece , the carrier has no identifing marks & could eb from the 50s , clutch sure grip , you might be able to figure some out using the part # from the ring gear
Logged
JonS
Jr. Member
Reply #4 on:
December 15, 2010 - 11:14:36 AM »
Chryco,
Thanks for the help! I suspected, but wasn't sure... It is definitely a 3.00 ratio using the simple turn test.
The ring gear is stamped with what appears to be the following:
2467450 P3 00 S291 1 68 N1X
Directly behind the ring gear (but not the gear itself) it is stamped with:
33712
There are other stampings all over it, but those are the ones near the gear.
Any ideas?
Jon
Logged
burdar
Sr. Resident
Reply #5 on:
December 15, 2010 - 11:30:00 AM »
My first guess was that it was a race piece too. The fitting that's plumbed into the side I'm sure is for a rear end cooler. 3.00 gear would be good for top end speed on a larger track.
Logged
Cooter
Sr. Member
There goes the lone Challenger............
Reply #6 on:
December 17, 2010 - 06:40:04 AM »
Thing is, from 1958 (First Sure Grip unit), the 8 3/4 chunks all look identical from the outside..I think this one is from 1958-1961 personally..
Logged
1969 dodge Charger "General Lee" [___|______I______|___]
1968 Dodge Dart 2dr sedan 505" Stroker (O]=0==========0=[O)
1970 Challenger R/T Clone "Kowalski Special" (OO) [___________] (OO)
Moparal
Permanent Resident
Reply #7 on:
December 17, 2010 - 07:49:34 AM »
It may have course spline axles. 62 or so and down were like 10 spline. thin ring gears too
Logged
JonS
Jr. Member
Reply #8 on:
December 17, 2010 - 01:30:58 PM »
My eyes were getting crossed trying to count, but it appears to be roughly 32 spline (?). It's definitely not 10.
I don't know if that helps or makes things more confusing...
Jon
Logged
JonS
Jr. Member
Reply #9 on:
December 17, 2010 - 01:59:12 PM »
I also noticed today that on the ID tag for the gear ratio it is stamped "R" right after the "3.00" stamping.
I know that Suregrips usually had the "S" stamp. Doesn't anyone know what R is?
Jon
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #10 on:
December 22, 2010 - 02:53:32 PM »
I honestly do not have a clue what the R or the carrier is from , definatly for racing with the cooler fitting , 3.00 is an odd ratio too , the side gears are usually 30 spline
sure grip is usually a seperate tag , R could be a race designation
Logged
JonS
Jr. Member
Reply #11 on:
December 22, 2010 - 09:49:15 PM »
I'll claim ignorance here... but the fitting for the cooler is kicked toward the rear of the car. Where would it have been mounted? Is there any chance this is just some type of breather? The fitting is just slightly higher than the fill plug...
Is there anything else I could do or provide that might help identify this further? How about an actual spline count? There are other stampings on the gears and INSIDE the carrier. Maybe I could take some close up pictures of those?
I'm really curious to learn more about this. I guess measuring the pinion gear shaft diameter would tell us a bit more as well... yes?
Jon
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #12 on:
December 24, 2010 - 07:50:21 PM »
the spline count means nothing , the #s on the gears & the pinion diameter would help
Logged
Alaskan_TA
Guest
Reply #13 on:
December 25, 2010 - 06:16:22 PM »
Is the broadcast sheet in the seat for one of your cars or from a parts car? Have you checked those other seats for more yet?
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #14 on:
December 26, 2010 - 09:46:47 AM »
By chance the new Mopar Collectors Guide came a couple of days ago & they have an article on a couple of mystery chunks that do have part numbers but are completely unknown as to their origin. They are beefed up versions & speculation is they were special pieces produced prior to '64 (pre-Dana) for stock car racing.....You just might have something very special there.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
