Author Topic: ladder bars  (Read 1189 times)
Offline cuda99
  • I'm a llama!
ladder bars
« on: November 21, 2004 - 04:47:04 AM »
I want to install ladderbars on a 71 cuda but i dont know if i need a panhard bar or a diagonal link, also want to know the total weight on the rear wheels and do you need the upper mount kit , can someone tell me the absolutely widest tyre wheel combination with shorter axle housings like 83/4 a or b body and wich backspace is needed. thanks for help and greetings from holland.
Re: ladder bars
« Reply #1 on: November 21, 2004 - 12:57:17 PM »
WIth the ladderbars therer eare 2 ways to go you can keep the leafs & use floaters or you can eliminate the leafs , use coil overs , with coil overs you will need to use a diagonal link & you need to install a proper upper mount for the coilovers to mount to , the rear weight wil be approx 1400 lbs depending what you sue for a fuel tank & if the batterys are mounted in the rear , max tire size is approx 13" wide without the leafs & with stock frame rails
Offline cuda99
  • I'm a llama!
Re: ladder bars
« Reply #2 on: November 22, 2004 - 01:32:34 AM »
thanks for the reply :)
Re: ladder bars
« Reply #3 on: November 23, 2004 - 01:07:36 AM »
No prob  8)
