Author Topic: how to tell an ebody trans?  (Read 2203 times)
Offline 7samurai
« on: December 16, 2010 - 11:10:42 PM »
is there an easy way to determine if an A833 trans is an e body?
often times you have to make a quick decision and go by what the seller tells you.  trying to find one for my conversion.
Offline 72bluNblu
Re: how to tell an ebody trans?
« Reply #1 on: December 17, 2010 - 03:05:29 AM »
The easiest way to tell is that E body transmissions will have 2 shift pad mounting locations. They also use a longer tailshaft, but that's easier to tell if you can compare them to a short tailshaft unit.
Take a look in the pictures here, plus lots of great info on 833's
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
Offline 7samurai
« Reply #2 on: December 17, 2010 - 05:01:22 PM »
ok, but the later (after '75) look identical in pictures or descriptions, but they have the overdrive and larger retainer, which is not what I am looking for.
Offline 72bluNblu
« Reply #3 on: December 17, 2010 - 07:20:40 PM »
So, now you want to know how to identify an 833 OD vs a regular 833?
This is pretty easy too. If it has an aluminum main case, its an OD transmission. The other dead give away is the front bearing retainer. The 833OD uses a 5.25" diameter bearing retainer, which is larger than the regular 833's.
An e body 833 will have a cast iron main case and 2 shift pad mounting locations.
« Last Edit: December 17, 2010 - 07:22:37 PM by 72bluNblu »
Offline Aussie Challenger
« Reply #4 on: December 17, 2010 - 11:59:06 PM »
Some of the later A833 non OD trans had the larger front bearing. Aluminum case usually identifies the OD, if rear extension housing has 2 pads and the rear one is taped & threaded it will fit the E body even if it came out of something else but you will need to buy the correct length levers and mounting bracket if the front pad was used as it won't bolt up to the rear one.
Offline mopar12372
    • mopartech
« Reply #5 on: December 18, 2010 - 10:58:31 AM »
wich one will fit the 11in clutch ? is the bell housing the difference between a engine and b/rb/h.
RESTO PICTURES
Offline 72bluNblu
« Reply #6 on: December 18, 2010 - 08:06:14 PM »
For the most part yes, the bell housing is the only difference between the A and B/RB/H engines. The A833 gearbox can be the same for both the A and B/RB/H engines. Some weren't, as some of the B/RB/H A833 transmissions were 18 spline. But a lot of them weren't, they were the same 23 spline A833 that the A engines got.
« Reply #7 on: December 22, 2010 - 03:10:38 PM »
the 11" clutch is confusing
there are 2 belhousings & flywheels , the larger is 143 tooth , the smaller is 130 tooth
 either can use the 23 or 18 spline disc as long as you spec the correct disc when ordering , the bolt pattern is different between the 143 & 130 tooth so the clutch is specific , both use the same 11" disc though
 the b & rb engine use the same belhousing
Offline mopar12372
    • mopartech
« Reply #8 on: December 22, 2010 - 05:25:16 PM »
will a 23 spile hold up to a high hp engine ? the 18 is a little hard to come by.
RESTO PICTURES
« Reply #9 on: December 22, 2010 - 08:35:27 PM »
yes the 23 spline will hold up
Offline mopar12372
    • mopartech
« Reply #10 on: December 22, 2010 - 08:36:53 PM »
thankyou
RESTO PICTURES
