Author Topic: Can't find my buns  (Read 2690 times)
Offline Dusty1
  • Revived
Can't find my buns
« on: December 17, 2010 - 11:20:31 PM »
I can find seat foam for '70 & '71 Cuda seats and '73 & '74 but not for my '72. Does anyone know why the '72 foams aren't available and if it matters much if I use another year foam and my correct year covers. Thanks!
Garys 1972 BS
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Can't find my buns
« Reply #1 on: December 17, 2010 - 11:40:23 PM »
70 to 71 foams are different,will not work with your stock 72 covers,,,I don't know about the 73 to 74 other than they don't have the hard plastic back which would make some difference,,the bottom may be the same but I don't know for sure
72rtchallenger
what happens in the garage
stays in the garage
Offline Dusty1
  • Revived
« Reply #2 on: December 18, 2010 - 12:12:53 AM »
Did you not have to replace your foam? Thanks
Garys 1972 BS
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #3 on: December 18, 2010 - 12:43:29 PM »
Sorry, no idea about the seat foams but the title of this thread made me curious/giggle....  :roflsmiley:
Offline 73Chally
« Reply #4 on: December 18, 2010 - 03:13:40 PM »
Your best bet will probably be to rebuild the foam.  I'm not sure if Cuda's are the same as Challengers, but you can not buy foams for 72 and up, because the foam was basically part of the seat bottom.  As a result, when I had mine recovered, the shop just used their own foam and rebuilt what was left.
Offline Dusty1
  • Revived
« Reply #5 on: December 18, 2010 - 04:23:21 PM »
I thought that title might get some attention :feedback: My foam is pretty rough especially on the outside of the drivers side. I guess I'll see what they can do with these. Thanks!
Garys 1972 BS
  • 72 to 70 clone
    • cardomain
« Reply #6 on: December 18, 2010 - 06:49:34 PM »
when I did mine I found a good bottom foam from an original seat out of a 73,to replace my only foam that I could not use,, my backs were fare and only had to add a little extra padding on one side and I  was good to go,,its a pretty hard job to do it yourself but has lack of funds I tackled mine and they turned out good,,as the 72 has a type of wire frame that attaches on the cover and pulls it up to the foam ,,the bottoms are not has hard,,I found one good bottom on ebay and stretched mine to it,,and just the foam can be used on either side doesn't matter if its passenger or drivers,,I cant remember if the backs will swap or not
72rtchallenger
stays in the garage
Offline Dusty1
  • Revived
« Reply #7 on: December 18, 2010 - 10:49:14 PM »
Thanks for the info! That helps
Garys 1972 BS
Offline shadango
« Reply #8 on: December 23, 2010 - 02:32:36 PM »
The guy at the Legendary tent at the last Carlisle told me that 72 and up you couldnt change the foam as it it modled to the frame of the seat.....
  • 72 to 70 clone
    • cardomain
« Reply #9 on: December 23, 2010 - 06:16:29 PM »
i removed my back frames,from the molding,they will slide out,the bottoms i dont remember but i know the backs will as i did my own
72rtchallenger
stays in the garage
Offline black71
  • eph 6:12
« Reply #10 on: January 02, 2011 - 02:12:47 AM »
 Anyone have pics of the different seats? I'm not sure which ones I have in my car....they have the plastic back on them though
  • 72 to 70 clone
    • cardomain
« Reply #11 on: January 02, 2011 - 10:57:13 AM »
70 to 72 have the plastic backs,,you can see mine in my profile picture,,post a picture of yours,,if they have the same pattern as mine then you have a set of 72
72rtchallenger
stays in the garage
Offline black71
  • eph 6:12
« Reply #12 on: January 02, 2011 - 04:44:07 PM »
Bummer looks like the seats in my 71 are from a 72
  • 72 to 70 clone
    • cardomain
« Reply #13 on: January 02, 2011 - 05:39:39 PM »
some of the 71 bottoms are similar to the 72 but the back is alittle different,,like these on ebay
http://cgi.ebay.com/ebaymotors/1971-71-Challenger-Front-Rear-Seat-Cover-Set-/130469996499?pt=Vintage_Car_Truck_Parts_Accessories&hash=item1e609e27d3
72rtchallenger
stays in the garage
