dana
Author Topic: dana  (Read 1001 times)
Offline budrinker
dana
« on: November 21, 2004 - 08:23:53 PM »
i am looking for a dana60 and got this reply is it worth it
That would run you $2995 with the wilwood street disk brakes (with emergency
brake option), Spicer plate style sure-grip, 3.54:1 Richmond ring and pinion,
and trac-pac style of pinion snubber and spring purches.
Call me and we'll get one started for you. We require a 50% deposit at the
time of the order and can do that on a credit card.
Dale
Offline budrinker
Re: dana
« Reply #1 on: November 21, 2004 - 08:26:02 PM »
and i am keepin the car for the long haul come what may
see you guys at carlislie
Offline budrinker
Re: dana
« Reply #2 on: November 21, 2004 - 08:30:09 PM »
the quote came from these guys
http://gearsandrears.com/clearance.html
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: dana
« Reply #3 on: November 21, 2004 - 09:25:08 PM »
I like the way that e-brake is setup.  The newer Chevy's use that design to help prevent any damage to the rotors when applied.
One thing to look inquire about is what kind of warranty is on the axles and the rest of the set up.  I just recently bought a Moser, and was pleasantly surprise to find most of the parts had warranties on them (about 10 years!).  It helps make you feel better about spending the money.  Of course the warranties had a bunch of stipulations.
With the brakes included, that is probably on par with most of the new aftermarket setups.  I bought the Baer setup for my car and for all four corners and a new master cylinder.  It ran $1800.
« Last Edit: November 21, 2004 - 09:28:42 PM by HemiDog »
