Author Topic: Full trunk pan replacement?  (Read 1103 times)
Offline Edison1970
« on: December 19, 2010 - 09:50:31 PM »
Hey Fellas.  I purchased a Cuda that was a race car at one time.  The last guy gave up on it.  A little more work than he expected.  First task I am going to tackle is repairing the trunk pan.  It had a fuel cell in it which the last owner removed.  He gave me a two piece replacement from year one.  My question to you all is should I replace the whole trunk pan or just patch it.  The entire pan is solid except for the big hole in the center where the cell was.  I also noticed that the factory did a horrible job attaching the extensions.  I attached pictures to give you an idea what it looks like.
Thanks
Offline Edison1970
Re: Full trunk pan replacement?
« Reply #1 on: December 19, 2010 - 10:17:41 PM »
Here is a pic.
Offline elitecustombody
  • Supra collector
« Reply #2 on: December 19, 2010 - 11:17:38 PM »
I'd replace the whole thing,that hole is just way too big,plus there are too many drilled holes
Stefan B
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #3 on: December 19, 2010 - 11:58:42 PM »
I agree...  Replacing the whole thing would be a better fix.
Offline Edison1970
« Reply #4 on: December 21, 2010 - 09:08:00 PM »
Thanks for the replies.  I will replace it.  The small holes you see are from the spot weld cutter I used to remove the tank braces that were cut.  I see the spot welds on the top of the frame rails which seems pretty easy to cut and separate.  How do you cut the welds to the extensions and the wheel wells?   I appreciate your advice.  You guys are great.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: December 21, 2010 - 09:27:59 PM »
same way if you can get the spot weld cutter in there. other way is to use a die grinder or a cut off wheel, 1/8 or 1/4 disc will work. these are agressive so do a little at a time on the weld point only.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
