Pics of Classic Air Sanden AC brackets on a SB?
Author Topic: Pics of Classic Air Sanden AC brackets on a SB?  (Read 7280 times)
Offline nqkjw
Re: Pics of Classic Air Sanden AC brackets on a SB?
« Reply #15 on: December 24, 2010 - 07:58:38 PM »
When buying a compressor you have a few choices.
The Sanden SD4 is the basic,cheapest unit that will get the job done.
I've used Sanden SD7 which is a heavier duty,better quality and more efficient unit (based on advice from my AC bloke)
Dimensionally there is little difference between the two.
The SD7 is obviously more expensive but not outrageously so.
Burnouts are cool but Traction is the Action
Offline Katfish
  • 70 Challenger
« Reply #16 on: December 24, 2010 - 08:13:37 PM »
What application, car/model year can I look up?  When I check Summit, they show 508 or SD-7, are the mounting positions and the inlet/outlet ports all in the same spots.  They list at least 10-15 PNs.
Vintage Air 047000-SUR - Vintage Air Sanden Air Conditioning Compressors
View Image and Compare
 Compare
Air Conditioning Compressor, Sanden 508, Aluminum, Natural, 2-Groove V-Belt Pulley, HFC-134A, Each
Part Number: VTA-047000-SUR More Detail …
Estimated Ship Date: 12/27/2010
Transaction$198.95   + Wish List   Additional Info: Drop Ship
Vintage Air 046703 - Vintage Air Sanden Air Conditioning Compressors
 Compare
Air Conditioning Compressor, Sanden SD-7, Aluminum, Polished, 2-Groove V-Belt Pulley, HFC-134A, Each
Part Number: VTA-046703 More Detail …
Transaction$274.95   + Wish List   Additional Info: Drop Ship Vintage Air 046702 - Vintage Air Sanden Air Conditioning Compressors
 Compare
Air Conditioning Compressor, Sanden SD-7, Aluminum, Natural, 2-Groove V-Belt Pulley, HFC-134A, Each
Part Number: VTA-046702 More Detail …
Offline nqkjw
« Reply #17 on: December 24, 2010 - 09:38:22 PM »
Mate,i'm not an AC expert.
I just know enough to be dangerous :stirpot:
What i know is just what I've picked up from my AC contractor.
However,in the Summit list you quoted it appears the SD7 for $274 is the one I was advised to use.
Apparently smaller compressors build up too much head pressure resulting in blown out seals.
Main thing to watch for is that you get a compressor with the outlets on the side of the casing,not at the rear.Otherwise you'll never fit your sixpack on.
Offline Katfish
  • 70 Challenger
« Reply #18 on: December 25, 2010 - 10:08:55 AM »
Thx for the help, I went to the Sanden website and there are hundreds of PNs.  I'll give Vintage Air a call next week to see what they recommend.
Merry Xmas!
Offline Got JOB
  • Member since 2-14-06
« Reply #19 on: December 25, 2010 - 03:52:41 PM »
my compressors are model# u4456
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline Katfish
  • 70 Challenger
« Reply #20 on: December 25, 2010 - 09:14:31 PM »
Thx! That helps me narrow it down.
Offline nqkjw
« Reply #21 on: December 26, 2010 - 12:21:25 AM »
Haha - quoting the actual model No. is too easy to think of!!! :roflsmiley:
The one on my challenger is a Sanden SD7H15 model no. 7867.
