Author Topic: Road Lamps - Mustang?  (Read 5300 times)
Offline lahatte
« on: December 22, 2010 - 12:47:26 AM »
I wonder if anyone has tried using the 1967 or so Mustang fog lamps on the cuda.  The housings look identical from what I can tell.  The Mustang parts are far less expensive than the "Let's gouge the Mopar people" ones.  If only the Mustang light's trim ring didn't have that bar across it...
Anyone?
Clay
Re: Road Lamps - Mustang?
« Reply #1 on: December 22, 2010 - 01:19:11 AM »
Anyone?
Clay
I've thought about this before and studied them very closely at car shows. From what I can tell, the bulbs are identical to the Mopar ones. They say Ford and GE on each mfg. versions.
Offline CUDAMAN1970
« Reply #2 on: December 22, 2010 - 06:40:51 AM »
I have the Mustang fog lamps on one of my cars.  The bar can be cut out and you file down the "cut points" on each side.  Once they are installed, you really do not see the difference between the mopar ones.
Offline RB2929
« Reply #3 on: December 22, 2010 - 10:08:29 AM »
I want the Road Lamps, but the cost has placed them pretty fair down the list of upgrades.  This thread perked my interest, though.  Doing a little research in comparing prices, came up with the following.
B/E&A Restoration Parts
http://www.beaparts.com/list_items.aspx?body=E&cat=E&subcat=23
70-71 Cuda Road Lamps (Pair) $295
70-71 Cuda Road Lamp bezel (Pair) $75
Total: $370
Mustang Online Catalog
http://Http://www.mustangcountryintl.com/listitems.aspx?RootCat=Electrical%20%26%20Lighting&SubCat=Fog%20Lights&
1965 - 1967 Fog Lamp Housing Assemblies (Pair) $72
1965 - 1968 Fog Lamp Bezels without Bar (Pair) $86
Total: $158
$370-$158=$212 Savings
Do you think that the Mustang wiring harness will work?
70-71 Cuda road lamp wire kit - $99.00
1966 - 1967 Fog Lamp Wiring Conversion kit - $47.45
$99.00-$47.45=$51.55 Savings
Obvious Cuda required components:
70-71 Cuda road lamp brackets (Pair) $50.00
70-71 Cuda Road Lamp Wire Retaining Clips To Core Support. (Set 4) $15.00
71 Cuda road lamp relay $175
71 Cuda Road Lamp Switch $195
Required components: $435
+ Cuda lamp/wire: $469
Total = $904
+Mustang lamp/wire: $205.45
Total: $640.45
$904-640=$264 Savings
Any thoughts? Anyone with experience?
« Last Edit: December 23, 2010 - 10:04:27 AM by RB2929 »
Offline mikeg
« Reply #4 on: December 22, 2010 - 03:04:29 PM »
I went the Mustang route and cut the bars off. Thought you would be able to see where the bars were but you have to REALLY
get close to see where the bars were. Here are a couple of pics of them on my '71 Cuda
Offline mikeg
« Reply #5 on: December 22, 2010 - 03:07:56 PM »
On the top picture of the lights about half way down on the right hand side if you look close you can see a little red dot and just below that you can see were the bar was cut off. Like I said, you really have to look close to see were the bar was
Offline the_engineers
« Reply #6 on: December 22, 2010 - 03:23:31 PM »
I have them on my car.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline lahatte
« Reply #7 on: December 22, 2010 - 05:14:18 PM »
Awesome.  Thanks for posting guys.  That looks like the ticket.  As for wiring, I can make it work.  Don't need concours stuff for this application.  Also, the 71 models use a relay in the curcuit (sellers want $175+ for the stupid thing), and I'll just find something at Radio Shack, or adapt some other relay to do the job.  Geez.  It's just a freaking relay!
Thanks.
Clay
« Reply #8 on: December 22, 2010 - 05:47:30 PM »
I converted to higher-intensity headlights, so I'm running a relay for the highs, one for the lows, one for the fogs and a switching relay to flip-flop the highs and fogs so that they don't turn on at the same time.
I think I've got less than 0.5 amps going through the firewall for the headlight/fog circuit...your bulkhead connector will thank you.
Brooks
1971 'Cuda 360
Offline lahatte
« Reply #9 on: December 22, 2010 - 08:16:55 PM »
What kind of relays are you using?  Where did you get them?
Thanks.
« Reply #10 on: December 22, 2010 - 09:49:13 PM »
Just the standard Bosch-style ice-cube relays.  Radio Shack, Walmart, Autozone, Advance, NAPA, etc.
Brooks
1971 'Cuda 360
Offline hebeegbz
« Reply #11 on: December 22, 2010 - 10:05:39 PM »
I bought my last pair used from a swap meet ford vendor for 75.00 , I also buy my 70 style wings from ford . ford and mopar shared many parts vendors .
thread gone in 60 seconds
Offline solarguy
« Reply #12 on: December 23, 2010 - 08:50:39 AM »
I used Mustang lamps and the Mustang parts company I orderded them from, New england Mustang even had replacement bezels without the crossbars.  Total price a few years ago was like 150.  They look Great
Offline Chris Pauluk
  • New to the E game
« Reply #13 on: September 22, 2017 - 06:37:55 AM »
Very interesting information.
Has anyone found a bulb conversion for these housings to use a h3 bulb similar to H4 7" upgrades?
Sent from my SM-G930T using Tapatalk
Chris Pauluk
Eagan Minnesota
1973 Plymouth Cuda 340 4spd (70 AAR clone'ish) bought it that way..
Offline hofilbert
    • Phil's 1970 HEMI Cuda Convertible
« Reply #14 on: September 22, 2017 - 01:06:57 PM »
I recently re-installed my road lamps back onto my car, but before I did I went over to a friend's house to use his sandblaster setup to clean and restore my lights.  This friend is a Mustang Guru that buys and sells Mustang parts...a rather large parts house up here in the PNW for Mustang stuff, so he's very knowledgeable about Mustangs.  Anyway, the first thing out of his mouth when I showed him my road lamps was "Those are Mustang lights."  He swore they looked the same and were probably identical...until I showed him the Pentastar on the back.
So, unless you are going concourse and expecting judges to look your car over for stampings, yeah, you can probably save some money by using Mustang road lamps.
Be sure to check out my 1970 Hemi 'Cuda Convertible web site https://packlighter.com/cuda/mycuda.html
