Author Topic: 1969 Chrysler New Yorker Survivor 58k original miles  (Read 980 times)
Offline B5barracuda
« on: December 22, 2010 - 07:45:00 AM »
Ok,first off,i bought this car to use as a driver,and upon going to pick it up and drive it back home 230 miles,i realize it is far to nice to use as the driver i need it to be.It is a 1969 new yorker four door,F3 green with champagne and green interior,58k miles on the ticker the 440 runs great,the car just floats and controls effortlessly,everything works,no rust(except just a little surface rust along bottom of pass rear glass),all glass is flawless,trim is beautiful,no dings,no dents,no accidents,100% original paint,i took a bit of rubbing compound to a spot on the trunk and i am certain that it will shine up and come back to life.
There is one rip in the front seat other than that interior is perfect,am high power radio works,power w
indows all work,the ac even works,and the heater will straight up run you out.
The car was owned by an old lady who died in 2007,thats when the guy i bought it off of bought it.The car was garaged all its life until 2010,till this guy lost his storage and had to sell.
I replaced a few bulbs,changed the oil and filter,put on some great used 235 75 15 inch tires,i also installed new front brake calipers and brake pads,brakes are great.
I would drive this car clear across the country with no hesitation,and when i drove it the 230 miles,and it got somewhere between 12-15 MPG.
You can fly in,ill pick you up at the airport,and you can drive it home.
The car is located in St Louis MO.
$3000 for this time machine
Thanks for the free ad.
rolemike@msn.com
2010 CHALLENGER S/E DEEP WATER BLUE
1970 CORONET 440 FOUR SPEED 30K ORIG MILES
1969 SUPERBEE 383 AUTO 99 PAINT CODE
1996 INDY RAM PACE TRUCK
