Author Topic: harness rebuild  (Read 2331 times)
Offline black71
  • eph 6:12
harness rebuild
« on: December 25, 2010 - 07:27:45 PM »
weighing in my options here... anyone know who and have a ball park about rebuilding my original harness?
Re: harness rebuild
« Reply #1 on: December 25, 2010 - 07:49:30 PM »
Which one?
Have you considered just buying a new one?
I used to be in the wire harness business. The way we would build a new harness from an existing one would be to take a piece of plywood. Using nails and colored felt pens, we would use the nails and different felt pens to tree out the original. Then copy it onto another one using the original as a template. Then build the new one from what we first built. So you can see it can be time consuming. By doing it this way, you'll ensure you copied the original just like it was. Wire needs to be TS 16949 certified, RoHs compliant,
You'll need good crimping tools. Machine crimping and stripping is far superior to hand crimping since it never creates inconsistentsies in PSI or wire stripping.
Re: harness rebuild
« Reply #2 on: December 25, 2010 - 07:56:21 PM »
Offline dutch
Re: harness rebuild
« Reply #3 on: December 26, 2010 - 10:57:41 AM »
Jim repairs wiring harnesses.  Top notch work too  :2thumbs:    E-mail him instead of PM.  doesn`t use pm.
http://www.cuda-challenger.com/cc/index.php?topic=64880.0
*** Bart ***
Offline black71
  • eph 6:12
Re: harness rebuild
« Reply #4 on: January 01, 2011 - 07:14:24 PM »
thanks fpr the info, whats your take on ron francis? are they pretty easy to install?
Offline dutch
Re: harness rebuild
« Reply #5 on: January 02, 2011 - 03:28:45 AM »
I`m almost done installing the RF wiring in my car. I like it for the fact I could install the fusebox in a different location, getting rid of the always problem giving bulkhead connector and the great quality of used materials, but it`s not plug in and play.  There`s no wiring included for heater/ air ,or wipers either.
*** Bart ***
Offline black71
  • eph 6:12
Re: harness rebuild
« Reply #6 on: January 02, 2011 - 02:13:22 PM »
Hmm ok....so compared to a painless kit?!?!
Offline dutch
Re: harness rebuild
« Reply #7 on: January 02, 2011 - 04:59:19 PM »
can`t help you there. never used painless.
*** Bart ***
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
Re: harness rebuild
« Reply #8 on: January 02, 2011 - 05:55:51 PM »
I did the painless in my 71 and it was ok.  It isn't drop in.  It is a universal Mopar Harness so there are no ends or anything.  You will need to cut and splice stuff.
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
Offline black71
  • eph 6:12
Re: harness rebuild
« Reply #9 on: January 04, 2011 - 01:04:00 AM »
So what is your guys' vote as to best bet for wiring
Offline dutch
Re: harness rebuild
« Reply #10 on: January 04, 2011 - 06:22:50 AM »
when a nice #-matching car would be involved, I`d vote for restored factory wiring in a heartbeat.  If not, choose what suits your application best.  I`m glad I picked RF. I modified my dash and console, and this wiring allowed me to change position of the fusebox and hook up the new gauges easy.
*** Bart ***
Re: harness rebuild
« Reply #11 on: January 04, 2011 - 07:52:41 AM »
I'd just pm, Slotts myself. He can rebuild your harness and does an excellent job.  He will do what it needs to make it as new with no short cuts and no worries
