H4 bulb conversion
Author Topic: H4 bulb conversion  (Read 1040 times)
Offline 73restomod
H4 bulb conversion
« on: December 27, 2010 - 03:18:00 AM »
Anyone do this swap on a cuda or chally yet? I saw that Zoops makes the housing in the right size, but i would think that even a new factory harness would be a fire waitin to happen with those bulbs current draw.
Offline Giveitawack
    • ebay
Re: H4 bulb conversion
« Reply #1 on: December 27, 2010 - 03:33:35 AM »
I used Volvo H4 aftermarket housings. Check 120 and 140 models from 60s and 70s.
Fit perfectly in the stainless ring.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #2 on: December 27, 2010 - 06:37:39 AM »
With relays and upgraded wiring it's a snap somebody has a wiring drawing to do this on here.
Go Fast & Have Fun...
Offline Jim
« Reply #3 on: December 27, 2010 - 01:00:32 PM »
Several options out there. Bosch, Hella, Delta and more all make quality H4 conversion lamps.
The most important thing to do is make sure what ever you get has either DOT or ECE (E-code) certification. Everything else is suspect to be junk optically. You may not consider this important as the driver of the equipped vehicle, but I assure you that oncoming traffic considers this to be very important.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline the_engineers
« Reply #4 on: December 27, 2010 - 01:30:01 PM »
There are a few threads around about this.  Also, check out www.goodysgotacuda.com for his write-up.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline GoodysGotaCuda
« Reply #5 on: December 27, 2010 - 10:42:04 PM »
Site isn't up anymore  :sadwavey: The how-to's should have made it over to here under the threads I've posted.
http://www.cuda-challenger.com/cc/index.php?topic=67743.msg695415#msg695415
I do have some LEDs around here somewhere (w/DOT #s), they may get stuck in the Wrangler though  :grinyes:
« Last Edit: December 27, 2010 - 10:45:05 PM by GoodysGotaCuda »
1976 Dodge Warlock
Wheel & Tire Specs:Link
