Author Topic: 440 bell housing question  (Read 1967 times)
Offline theblurr
« on: December 27, 2010 - 11:06:07 AM »
Hello, I have found a cast iron bell housing for sale for a big block mopar for 125.00, how can I tell if it is the correct one for our 74 challenger w/833, also brewers has a new aluminum bell housing for 299.00, would it be better to buy the aluminum bell housing and will it hold up? Thanks Brent
'I will live until I die,
Then I will live forever.'
                    Brent
Re: 440 bell housing question
« Reply #1 on: December 30, 2010 - 09:08:34 PM »
the cast belhousing is for the 143 tooth flywheel , the alum is for the 130 tooth , do you have a flywheel yet ??
Offline theblurr
« Reply #2 on: December 30, 2010 - 11:09:15 PM »
Chryco, I dont have a flywheel for the 440 yet, I do have a 318 flywheel.
                    Brent
Offline Cooter
    • christinecarclub.com
« Reply #3 on: December 31, 2010 - 06:42:24 AM »
143 Tooth Flywheel is the 11" I think, and the 130 Tooth is the 10 1/2"....Flywheels are different as are the clutches...If mismatched, the starter won't even engage the flywheel...
If you get the cast, you will need a 318 "truck" 11" flywheel to make it work..If you buy the aluminum one, you will need a 10 1/2" 318 Car/truck flywheel...
« Reply #4 on: December 31, 2010 - 10:28:05 PM »
the 318 flywheel is a 130 tooth generally , still count it so you need an alum belhousing , there is the 10.95 large clutch available for the 130 tooth so you do not give up anything with the smaller flywheel , McLeod is the 10.95" clutch I would use
Offline theblurr
« Reply #5 on: January 02, 2011 - 08:28:22 PM »
Thanks fellows for the help on the bell housing. Brent
                    Brent
