Author Topic: Frame Measurements? Lead filler treatment  (Read 1201 times)
Offline pywell
  • Autobody Technician
    • PPC Customs
« on: December 27, 2010 - 10:27:47 PM »
Anyone have the frame measurements for a 74 challenger? I have to replace 3 of the 4 frame rails and would like to try and find the measurements to make them accurate.
Also does anyone know the name of the chemical used to treat the lead filler before primer etc... is added?
Offline 72bluNblu
Re: Frame Measurements? Lead filler treatment
« Reply #1 on: December 28, 2010 - 02:50:45 AM »
3 of 4? That'll be fun! Here you go...
« Last Edit: December 28, 2010 - 02:52:41 AM by 72bluNblu »
Offline pywell
    • PPC Customs
« Reply #2 on: December 28, 2010 - 10:47:01 AM »
Thanks!! Ya 3 of the 4, drivers front is got a crack right down the center of it and the battery rotted right through the front of it. Then the drivers rear was spliced and not done right, looks terrible. And the passenger rear has rot through it. Purchased 3 new clean full length frame rails to make it look new again.
« Reply #3 on: December 28, 2010 - 11:09:59 AM »
From Resto Rick's website:
Wipe the surface with PRE Painting Prep or Acetone and dry with a clean soft cloth.
At this point a skim coat of polyester body filler can be applied to get the contour exactly right.
Offline pywell
    • PPC Customs
« Reply #4 on: December 28, 2010 - 02:03:25 PM »
Thanks, that is perfect. Its been years since I had to do it, I just could not remember.
