I was re-reading this thread from the beginning.
Can you explain post #3 a little more: "The KPI on the e-body spindle I measured at 5 degrees, on the C-Body I measured it at 7.5 Degrees. To measure it I mounted the spindle pin in the lathe and then used a precision bevel protractor and measured the machined flat surface on the top of the spindle." Where exactly did you machine? What does KPI stand for, and SAI?
Thanks Brad!
Matt
