Author Topic: Header Gaskets  (Read 1051 times)
Offline mojavered
  • Someday!
Header Gaskets
« on: December 29, 2010 - 01:11:48 PM »
Is it worth it to port match the header gasket to the header?  I have 2" tti's and Percy's gaskets but the opening is 1.5" x 1.8".  I am not sure, but the header openings are probably 1.7ish" x 2.0".  Will it make much difference?
Jason
Offline Cooter
    • christinecarclub.com
Re: Header Gaskets
« Reply #1 on: December 29, 2010 - 01:16:34 PM »
Anything hangin into he port is worth por matching...Even the gaskets...No sense in spending the HUGE money for those TTI headers and letting a $5.00 gasket scew up the flow...
« Last Edit: December 29, 2010 - 11:14:55 PM by Cooter »
Offline GoodysGotaCuda
Re: Header Gaskets
« Reply #2 on: December 29, 2010 - 04:49:21 PM »
Yep, I sure would. Will it kill your coating though/cause rust?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline mojavered
  • Someday!
Re: Header Gaskets
« Reply #3 on: December 29, 2010 - 10:25:33 PM »
Anything hangin into he port is worth por matching...Even the gaskets...No sense in spending the HUGE money for those TTI headers and letting a $500 gasket scew up the flow...
Thanks.  I think I will use my TTI gaskets for a while...they are the correct size.  Anyone ever put any copper sealant or anything on them?
I am only talking about the gasket.  The header flange will not be touched.
Jason
Re: Header Gaskets
« Reply #4 on: December 30, 2010 - 08:55:59 PM »
I use high temp Ultra Copper RTV sealant
 Definatly worth port matching
