Author Topic: Flexible Transmission lines.  (Read 3663 times)
Offline Cruzin
  • I love YaBB 1 Gold!
« on: January 04, 2011 - 02:50:10 PM »
I would like to replace the factory transmission line with a flexible line so I can route it away from the headers.  I prefer one of the newer type of hoses rather than a steel braided line.  What would you recommend and is a -4 the correct size? Also, I'm going to need fittings for the radiator and to screw into the transmission (what size fitting??).
340/727/E-body
Offline the_engineers
Re: Flexible Transmission lines.
« Reply #1 on: January 04, 2011 - 05:59:16 PM »
Factory steel is 5/16 with OD tranny's using 3/8.  -4 is roughly a 1/4" IIRC, so I'd look at either -5 or -6
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline 72cudamaan
« Reply #2 on: January 04, 2011 - 06:11:37 PM »
Yes brock (?) is right on the sizes. Hydraulic ( I believe) is measured in 1/16 increments  ie -6 = 3/8/ -8 = 1/2 and so on. Teflon lines are available but keep in mind that without the armor or protection of a solid line or steel braiding, you do run the risk of damage if something were to hit the line.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Cruzin
« Reply #3 on: January 05, 2011 - 11:39:24 AM »
72cudamaan and the_enginners,
Thanks for you feedback.  Have either one of you replaced/rerouted your transmission line with something else such as a flexible line?  If so, what did you use?
TIA
« Reply #4 on: January 05, 2011 - 04:59:11 PM »
I ordered 3/8" steel lines for my 518...that's the furthest from stock that I've gone on that.
Brooks
1971 'Cuda 360
Offline UKcuda
  • Tell them I'm on my way
« Reply #5 on: January 17, 2011 - 05:16:36 AM »
TIA
When I got my car my cooler lines were actually touching the headers so I re-routed them in 8mm copper tube and I took it along the frame rail well away from the exhaust.  New copper tube bends easily.
The tricky bit was getting some flexible sections over to the box in/outlets.  The stock lines move with the engine/box and can twist some at the front so they can be solid with no problems.  If they run along the body then the way the box moves with the engine makes it essential to have flexible sections across to the box.
I used some flexible lengths I cut off a Jeep attached with jubilee clips, there's not much pressure in them.
'72 'cuda
