Author Topic: Correct Carb for 1970 440 Magnum - Challenger  (Read 4180 times)
Offline 72ls5fla
« on: January 04, 2011 - 10:03:45 PM »
Hello-
Does anyone know the Correct Carb for 1970 440 Magnum - Challenger
make, Model ??
Info is appreciated!!!
Thanks
Bill
Offline Challenger6pak
Re: Correct Carb for 1970 440 Magnum - Challenger
« Reply #1 on: January 04, 2011 - 10:34:15 PM »
It would be a Carter AVS.  I don't have a number here at this time.  A different carb was used for automatic and a different carb was used for the 4 speed.
Offline RusTy/SE
  • Just havin' fun
« Reply #2 on: January 04, 2011 - 10:42:32 PM »
For my 1970 440 A/T Non A/C Non California Emissions it's the 4738 AVS
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline 72ls5fla
« Reply #3 on: January 04, 2011 - 10:45:25 PM »
thanks for the info!!
I had it in my head a Holley was used ---   getting old I guess... :eek4:
« Reply #4 on: January 07, 2011 - 12:36:46 AM »
some use small 600 cfm Holleys but definatly not the ultimate for performance , more 383 s used the Holley
Offline beekppr
    • Dodge Challenger Project
« Reply #5 on: January 08, 2011 - 10:18:53 PM »
According to "Mopar Broadcast Sheet Decoding Manual"...
440 4bbl high perf w/o E.C.S. is Carter 4737S for manual trans and 4738S with auto trans
If you have E.C.S., then it is Carter 4739S for manual trans and 4740S with auto trans
If you have a/c and auto trans, but no E.C.S., it is Carter 4741S.
Holleys were used on the std. perf. 440 motors this year according to the book. Holleys were also used on the 383 perf. motors this year.
I used this book to break down everything on my super bee's broadcast sheet and it was right on the money on everything. By the way, this book mentions codes for just about every factory part Mopar bolted onto our cars.
