Author Topic: Energy Bushings?  (Read 1961 times)
Offline Dusty1
  • Revived
Energy Bushings?
« on: January 05, 2011 - 11:29:11 PM »
A few months ago, I bought all the bushings I would need for my rebuild. Today I was ready for my leaf spring bushings, but the kit had only 2" main eye bushings and I needed the 1 1/2" bushings.
I just was wandering why these springs are this size? When ordering it says the 426's and 440's have this size(1 1/2") and if anyone has any of the 1 1/2" polyurethane bushings so I don't have to buy another whole kit. Thanks!
Garys 1972 BS
Re: Energy Bushings?
« Reply #1 on: January 06, 2011 - 12:28:59 PM »
Mopar had two different sized leaf eyes. It is possible your springs got swapped out at sometime in its life, or when it was assembled they simply grabbed the next set available and put them on. I've noticed the larger eye springs tend to be on older, pre 70 cars, but nothing is an absolute with mopar.
Two options, take your 2" to a shop and have them turned down to 1.5, or pick up another set of 1.5" units.
Offline dutch
« Reply #2 on: January 06, 2011 - 01:47:30 PM »
 :iagree:  turn them down to 1.5...  it`s a 5 minute job
*** Bart ***
Offline Dusty1
  • Revived
« Reply #3 on: January 06, 2011 - 07:08:36 PM »
How do they turn down a urethane bushing? What kind of shop does this, a machine shop?
Garys 1972 BS
« Reply #4 on: January 07, 2011 - 12:11:44 AM »
anyone with a lathe should be able to trim them down in minutes
Offline Dusty1
  • Revived
« Reply #5 on: January 07, 2011 - 12:22:13 AM »
Thanks! I can work with that.
Garys 1972 BS
Offline 73EStroker
« Reply #6 on: January 17, 2011 - 08:59:38 PM »
FWIW mine had the same issue so I took the problem ones back to the vendor and they swapped them for the correct ones. Just Suspension needs to work on this as it most likely happens a lot.
Barry (Salmon Arm)
Offline cuda346pk
« Reply #7 on: November 17, 2013 - 01:42:30 AM »
I have just run into the same thing with PST Polygraphite ones. they dont offer the 1 1/2" ones. Shouldn't be a problem to turn these too would there? Gotta go get a grease groove cut in my LCA pins any way, may as well hit him up for both.
David - In Georgia
1972 'Cuda In-Violet 340 6 Pack 4 Speed 3.91 Sure Grip - Finally, after 27 years of waiting and dreaming it is real. Now the fun begins!
« Reply #8 on: November 17, 2013 - 10:06:02 PM »
same thing , poly graphite or poly urethane both can be trimmed down
Offline cuda346pk
« Reply #9 on: November 19, 2013 - 03:34:01 AM »
I figured the impregnate graphite would not matter as far as turning it.
David - In Georgia
