Cruise control
Author Topic: Cruise control  (Read 6367 times)
Offline roy282
Cruise control
« on: January 07, 2011 - 10:38:52 PM »
At last after many hours/day/weeks/years on EBay I finally found the cruise control lever. the whole green column out of a 71 plymouth fury for 59.99 BIN You have to love EBay!!! Anyway does anybody here know how to disassemble one of these??? so I may clean up the connection inside.   Thanks Rob
    Thought I'd throw in a couple of pics
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
Offline Katfish
  • 70 Challenger
Re: Cruise control
« Reply #1 on: January 07, 2011 - 10:43:50 PM »
 :popcorn:
I actually want to remove the cruise lever from mine and put a standard 1 back in.
Offline Challenger6pak
Re: Cruise control
« Reply #2 on: January 07, 2011 - 10:49:14 PM »
Isn't the Cbody cruise control a longer lever even though it looks the same?
Offline roy282
Re: Cruise control
« Reply #3 on: January 07, 2011 - 11:03:14 PM »
Why would you want to do that? Katfish Does it work still?Does it cause any electrical issue?Thanks for any info Rob
Challenger6pak: the lever I have seems to be about 3/4" shorter then a standard one.
Re: Cruise control
« Reply #4 on: January 07, 2011 - 11:07:25 PM »
What do you mean by standard one?  I was told there was a difference.  There may not be a difference.  I am just curious and wanting to learn more about an unusual Ebody option.   Thanks.
Offline roy282
Re: Cruise control
« Reply #5 on: January 07, 2011 - 11:14:17 PM »
Sorry Challenger6pak by standard I meant a non cruise control one.
Re: Cruise control
« Reply #6 on: January 07, 2011 - 11:25:14 PM »
My question may not have been that clear.  I was under the impression that a Cbody cruise control lever was longer than the Ebody cruise control lever even though they had the same appearence.  One just used a longer shaft.
Offline roy282
Re: Cruise control
« Reply #7 on: January 08, 2011 - 11:00:23 AM »
Challenger6pak I'm not sure if they are different in length or not? Maybe if Katfish would be so kind to take a measurement of his or anybody else for that matter with a factory cruise lever we may find out!Thanks
Offline Katfish
  • 70 Challenger
Re: Cruise control
« Reply #8 on: January 08, 2011 - 11:23:30 AM »
Mine measures 6" from the column to the end of the switch.  What is the std style length?
Re: Cruise control
« Reply #9 on: January 08, 2011 - 11:45:48 AM »
Send me your e-mail and I can send you the file on how to work on your steering column.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: Cruise control
« Reply #10 on: January 08, 2011 - 11:47:10 AM »
If I remember correctly the angle is different on the ebody than a cbody because of the crush can most likely.
Go Fast & Have Fun...
Offline roy282
Re: Cruise control
« Reply #11 on: January 08, 2011 - 11:59:22 AM »
PM sent Topcat. Thanks
Offline roy282
Re: Cruise control
« Reply #12 on: January 08, 2011 - 12:08:42 PM »
Here is pic of the cruise lever with the measurement  from the 71 fury.
Offline dutch
Re: Cruise control
« Reply #13 on: January 08, 2011 - 12:39:50 PM »
that lever is different from mine.  I`d replace mine for one without cruise too....
*** Bart ***
Re: Cruise control
« Reply #14 on: January 08, 2011 - 02:24:28 PM »
I looked up the part numbers for the Cbody and the Ebody cruise control.  They are a different part number.
