I am told a total advance of about 37-38 degrees is best but with your current curve, it seems to be all in a bit late to me. The lighter spring should do the trick but you will spend hours playing with different combos to get it just the way you like.
Out of curiosity, why do folks always hook the vacuum advance back on after getting the initial and mechanical advance just right?
My initial is around 15 with total of 38 at around 2500-2800 rpm. Seems to work well under all conditions with no pinging but if I hook up the vacuum advance, my total advance becomes 50 which cant be good. Plus it is a bear to get everything readjusted well and running halfway decent. I keep trying to use it but find it's better without for some reason.
By the way, those are really high vaccum readings. I'm jealous.
