Questions about my 440 6 pack
Author Topic: Questions about my 440 6 pack  (Read 16535 times)
Offline tommyg29
« on: January 09, 2011 - 08:29:03 PM »
can anyone "read" the carbs from these pictures, especially the main? I think I have had a few backfires because the underside of the cover has some dark stains on it.
Any comments? Thanks.
Offline beekppr
    • Dodge Challenger Project
Re: Questions about my 440 6 pack
« Reply #1 on: January 09, 2011 - 08:37:38 PM »
Do you hear it backfire? It's fairly noticable. They look gorgeous to me. I was gonna offer to trade for my 4bbl setup.
How does the car run after it's warm? Thats the best indicator. You can read plug color after using it under different types of conditions and fine tune the setup for best performance and drivability. Also, the vacuum pots on the outboard carbs have replacable springs which most people never mess with. Holley makes a set of lighter springs which can really wake up the car once you get them dialed in nice.
« Reply #2 on: January 09, 2011 - 09:00:11 PM »
did you have wires installed in the air bleeds of the center carb in the second Pic ??
 too many variables , backfire is usually lean , could be low float levels , lack of accelerator squirt , vacuum leak , lean idle mixture settings , have you adjusted the idle screws on the outboard carbs ?
It would just be easier foe my to fly down & tune it !!
Offline tommyg29
« Reply #3 on: January 09, 2011 - 09:58:48 PM »
its nice weather here huh?
I havent adjusted anything.
I'm afraid to let anyone touch em. At drive ins I have guys giving me their cards and claiming they can do this or that. It runs pretty well and holds a good idle at about 1000 rpm, so I'm afraid to touch anything anyway.
Yes there were a couple copper wires in the air bleeds. Moper had last worked on it for the prior owner a few years ago, and I finally just removed them a few months ago. I havent noticed much difference. After it warms up they seem ok (it doesnt get very cold here), but the plugs show the car runs very rich, and am told it used to lean out at higher throttle when the secondaries kick in, which seems odd.
But hey, if youre ever nearby, I'd be glad to pay YOU to give them a good go through. Maybe we could arrange a Florida winter group buy for your services!
Offline challengermaniac
« Reply #4 on: January 09, 2011 - 10:37:24 PM »
Chryco,
How about putting a list together of all the guys wanting a tune up and then mapping out a USA tour this coming spring to catch them one at a time?
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Offline beekppr
« Reply #5 on: January 09, 2011 - 10:41:43 PM »
When the car is at cruise on the open road for a while, if you were to pull a plug and check it, the color would be based on the jetting of the center carb. If it is rich, go a size down on the jets (assuming the rest of the carb is functioning normal)
At wide open throttle, the richness or leanness will be based on the jetting of everything. The outboard carbs should have jets or metering plates which can be changed to richer.
If I were you and you want some improvement until a true pro can look it over, I would cruise it on the open road, pull over and check the color of the plug for the center carb jetting. Then when youre satisfied, I would do some wide open throttle pulls with it and check the plugs again for outboard carb jetting.
A trick someone showed me is dont just check the number one plug and assume they are all the same. I have a felling that you could check the front cylinders and get one color and check the back cylinders and they would be different.
By checking front and back, you can get the outboard carbs jetted just right without much effort.
I have a 64 Corvette with a nice 4 bbl. I was having issues like yours, After checking a front and back plug, I discovered the primary side was a little rich and the secondary side was very lean. I would never had known otherwise. After making a quick jet change on both front and back, it was ten times better. Idles great, runs strong, intermittant overheating disappeared, just better in every way.
Offline nqkjw
« Reply #6 on: January 10, 2011 - 03:51:33 AM »
Yeah,keep them right away from them.
Tuning multiple carbs is an art.
Burnouts are cool but Traction is the Action
Offline Tom Quad
« Reply #7 on: January 10, 2011 - 06:59:52 AM »
do the dance
If you want real help you must do the dance
Here is a guide to tune six packs for street engines. Stroker or non stroker, big block or small block
This is not the final word, but close enough
Remember six pak engines run on the center carb and idle on all 3
The car must idle and run like a normal car before attempting any secondary action or wide open throttle passes.
A Good ignition system is required.,  MSD, Mallory or  FBO mopar box, NO orange boxes or chrome boxes unless you know for sure it is early 80’s vintage.  Anything made after 1988 is questionable.
Quality distributor cap & rotor
High quality spark plug wires like Firecore 50s
Spark plugs of the proper heat range.
Vacuum adv distributor
The distributor phasing has been checked and corrected as necessary
THIS IS IMPORTANT
Distributor vacuum port on carb disconnected and plugged at carb
Make sure the timing is 15 - 18 deg btdc [advance] at idle. THIS IS IMPORTANT
Set the timing marks at 15 btdc and align the rotor with the cap-this is one reason the phasing was checked.
in gear/parking brake locked, keep advancing the timing until the (manifold) vac is as high as it will go then back off the timing until the vac drops 1 in hg and as you are advancing the timing to get to this point keep bringing your idle speed (in gear) back to where it initially was. EDIT forgot the chart, they say it's not dead on but fairly close for a start
Car in neutral-auto or 4 sp, emergency brake set.
A good quality vacuum gage is required,
Connect vacuum gauge to manifold vacuum source.
ATTENTION -195 degree thermostat- ATTENTION
                          THIS IS IMPORTANT
If you run a lower temp thermostat, raw fuel will collect in the intake
That fuel then burns off in the cruise mode.
Unless you have a wideband air fuel meter you will not see this happening, but you will have problems getting it to idle and see the mixture go leaner in the cruise mode.
The heat crossover should be blocked on big & small blocks
Note: in temps below 40 degree it will take a good while to get the car warmed up. Block heaters will eliminate the long warm ups.
Set the outboards idle adj screws out 1/8 turn ccw THIS IS IMPORTANT
Be careful when seating the idle screws to set them, gently is the word
Install the BLACK springs – Just do it, ignore everything else you have read
Set the center carb idle adjustment screws at 1.5 turns out [ccw] THIS IS IMPORTANT
Check the center carb and be sure to adjust the idle screw until the throttle blades are closed and the transfer slot is exposed no larger than a square. [carb would have to be off the car to see this] You only want about .040" of the transfer slots exposed below the throttle plates.  If the idle screw is adjusted too high, you will be into the transition circuit, exposing too much of the vertical rectangular slot. Many times the idle screw is adjusted incorrectly to compensate for other issues. This puts the carb into the transition circuit and at that point you have no mixture control on the center carb.
If you have new carbs(untouched) they will have 62 jets in the center carb & a 6.5hg power valve The outboards will have the lead plugs covering the idle adj screws.
Starting point for center carb jetting stock 340 use 62’s, highly modified or stroker use 64’s,
Leave the outboards alone for now unless you have the jetable metering plates, if so read their instructions and follow them
You must know what power valve is in the center carb. Typically a 6.5
Fuel level adjustment THIS IS IMPORTANT, this is best done idling at 1000-1200 rpm
The slotted screw on top of the needle n seat is just a lock screw,
To adj the float level loosen the lock screw to rotate the seat nut,
Turning the adjuster nut counter clockwise will raise fuel level in the bowl, clockwise will lower it
Make only small 1/2 turns.
You must let the car run a 3 or more minutes so the fuel levels off before rechecking level
Center carb the fuel level is at the bottom of the sight plug hole
Secondaries it is just starting to come over the bottom of the sight plug hole
This is critical so get it right.
Set idle to 950 rpm and allow engine to reach operating temp.
Reminder 195 degree thermostat required or fuel will puddle in the intake.  .
If the car won’t idle:  Is engine vacuum reading at least 2 hg higher than the power valve rating?  If ok proceed, if not correct power valve issue and proceed.
Note some engines only pull 5 hg of vacuum so use a 2.5 power valve.
Now set the initial timing to where it wants to be.   Somewhere between 10-20 degrees BTDC.  The engine will tell you by increasing vacuum and rpm at this point.  In some applications the engine does not care, so set it to 12-14 degrees BTDC.
Cams with 106-degree ctrlines seem to like initial timing set at 16-22 BTDC
Cams with 108-degree ctrlines seem to like initial timing set at 12-18 BTDC
Cams with 110-114 degree ctrlines seem to like initial timing set at 8-14 BTDC
Re-Set the idle rpm for 900-See if you have "control" over the idle mixture screws on the ctr carb. Using a good vacuum gage adj center carb mixture to highest reading of vacuum.  If you do not have control over the idle mixture you have issues that need to be taken care of before proceeding.
Typically if you have the center carb idle mixture screws between 1 to 2 turns ccw
you do not have to adjust the outboard idle mixture any further. Starting with the front carb, adj the mixture screws one at a time 1/16th turn ccw, after turning each screw wait and see what the engine vacuum and rpm do.  Obviously if you have a wideband a-f gauge you will see what is happening.
Beware of issues such as poor intake sealing, carb gaskets backwards, the wrong pcv valve, a vacuum leak from the brake booster or other places, wrong pwr valve etc.
Recheck idle rpm and set to 900
Drive car like a normal person, no wide open throttle. Is the car rich? Jet down 2 steps until you find the min jet size.  You will know when you are lean as you will have no power.
Most times you are over jetted.... Do not over jet!
Over jetted carbs will have poor idle control.
Now reset the initial timing again.   Somewhere between 10-20 degrees BTDC.  The engine will tell you by increasing vacuum and rpm at this point.  In some applications the engine does not care, so set it to 15 degrees BTDC.
Re-Set the rpm for 900-See if you have "control" over the idle mixture screws. Using a good vacuum gage adj each mixture screw to highest reading of vacuum.  If you have a wideband afr meter set to 14.7
Recheck idle rpm and set to 850
How do you know when you are "there”?
The car will idle at 700-900 rpm in neutral and the response is crisp.
There is no smell of raw gas in the exhaust.
The bottom of the intake is not soaked with fuel.  Open a carb and look in
The spark plugs are clean.
The engine when cold starts easily, runs and drives smoothly from the get go.
The engine when hot restarts immediately without touching the throttle.
 When the engine is rev’d and the throttle released it immediately returns to idle.
OK if you made it this far it’s time for the Secondaries
The reason you put the black spring is to delay the opening of the secondaries until the engine is ready for it. The engine will run fine on just the center carb till at least 3000 rpm.  The air fuel mixture spikes lean when the secondaries open, but at higher rpms this is transparent and has no affect on performance. The opening of the secondaries should be seamless, but very apparent and usually scary to the uninitiated.
The long vacuum hoses for the outboard carbs need to be exactly the same length.
Pulling a vacuum on the hose should make the vacuum pod open the throttle blade and hold a vacuum
The best way to dial in the secondary air fuel ratio is with a wide band air fuel meter.
A fine tuned seatofthepantsometer and spark plug reading will work for the more experienced
If you made it this far and the car is bogging when the six pak opens you need to go back and recheck starting at the top.
Notes:
If the initial timing exceeds 12 degrees BTDC with a MP distributor typically the advance curve will need to be modified so the total timing is not more than 34 degrees BTDC.
Automatic cars with too tight of a converter will cause significant idle rpm drops when in drive, the car will not run at it’s full potential so be sure to use the correct converter for the application.
Some cars like staggered jetting.
 :help:
Offline nqkjw
« Reply #8 on: January 10, 2011 - 07:52:02 AM »
Good read Tom Quad :thumbsup:
But you'd have to admit,not the sort of process you'd want a novice to be tackling.
Here's one of my setups.
All homemade.All mechanical.
The two outboard carbs are 350cfms and are my primary carbs with 68 jets and 3.5 powervalves.
The centre is a 650cfm and my secondary (or thirdary as I call it :roflsmiley:) with 102 jets and no powervalve.
Works awesomely well much to the disgust of other "experts" who said it can't be done.
« Reply #9 on: January 11, 2011 - 10:17:41 PM »
I would start with pulling the rear carb & center carb off , pull the bowl & metering block on the center carb , replace the power valve & gaskets & reassemble it
Offline tommyg29
« Reply #10 on: January 11, 2011 - 10:40:43 PM »
wow,
lots and lots of great input here, and it may take me a couple more days to digest most of the manual you posted here Tom Quad :2thumbs:
I agree its probably too much for me, but....
I will learn from it, and may just try a couple of these suggestions, AFTER the florida mopar nats in March.
Its running well enough for now though.
Thanks for all the help :cheers:
Offline beekppr
« Reply #11 on: January 12, 2011 - 11:25:15 PM »
I really liked the detail Tom Quad. I wish I had a six pack to try it on. I do plan on using some of your advice with my regular power tuning stuff. Theres alot of good stuff in there.
Offline mopar12372
    • mopartech
« Reply #12 on: January 16, 2011 - 12:10:48 AM »
:iagree: back fires /hesitations  start here
RESTO PICTURES
Offline tommyg29
« Reply #13 on: January 16, 2011 - 05:00:37 PM »
took her out for a nice drive in the country today, and at about 3500 in 3rd gear, about 40mph, I gunned it, which means about 3/4 throttle for me (dont know if I've ever put it to the floor), and it jumped forward, and then after a moment of acceleration, wham... what felt like another momentary quick loud burst, along with a big cloud of white/grey smoke out back! Startled me for a moment. Thought I'd blown something, and then I figured maybe one or both of the outboards kicked in, or maybe shook loose some excess fuel from somewhere.
Had never felt that kick before.
Offline beekppr
« Reply #14 on: January 16, 2011 - 10:44:44 PM »
Your outboard carbs have vacuum pots on them with springs inside. The vacuum secondarys are supposed to come on smoothly if you have the right springs in them. Too light a spring and the car bogs when you stand on it. Too heavy a spring and the outboard carbs come on slowly and rather late. If you only pour on the power slowly and never stab the throttle quickly, then you would probably not notice the springs being too light or strong.
Was the experience good or bad? Strong acceleration sounds like it is dialed in nice but you describe good acceleration followed by another increase in acceleration which makes me think the springs in the outboard carbs are too strong. Holley makes a spring kit and they color code them to make dialing it in easy. With a little experimentation, you will find the exact stiffness you car likes. There is no danger of hurting anything and you will probably have a very responsive car when you're done. There is no way to guess which one is correct since things like rear end gearing, car weight, cam profile, etc all make the car behave differently.
This is an easy Saturday thing and it's fun to pop in new springs and test drive it to see if it's better or worse than the last. Much easier task than dialing in the jetting in my opinion and way more fun.
