Questions about a few leaks
Author Topic: Questions about a few leaks  (Read 3627 times)
Offline tommyg29
« on: January 09, 2011 - 08:33:59 PM »
here are a few pictures of my last couple small drips Im trying to eliminate. They dont drip often, but theyre aggravating.
Any advice?
Offline beekppr
    • Dodge Challenger Project
Re: Questions about a few leaks
« Reply #1 on: January 09, 2011 - 08:43:05 PM »
My guess is valve covers. If it is primarily ay the back, dont forget to chk the oil pressure sending unit. Just had one fail on me and it was leaking oil everywhere.
« Reply #2 on: January 09, 2011 - 09:02:21 PM »
the hads are never cast or machined flat , steel covers were used so they could conform to the uneven surface of the head , cast covers are very hard to seal as the will not flex to conform to the head ,
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: January 10, 2011 - 03:39:27 PM »
YuP,Valve covers. We used the rubber gaskets with "right stuff". And used little spring clamps to hold them in place on the cover over night. Then another bead around the head,and install. Not a drip.  Might want to do that fuel pump block off too just because. And the oil pressure is another good place to seal threads.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline tommyg29
« Reply #4 on: January 10, 2011 - 05:40:39 PM »
thanks guys,
that passenger side is giving me fits, but it looks like it isnt hard to come up with weekend projects. :2thumbs:
Offline tommyg29
« Reply #5 on: January 14, 2011 - 05:35:31 PM »
removed the blue silicone "moroso" gasket which had a couple cuts in it and just put one good bead of right stuff on the valve cover...first cleaned the surfaces up with brake cleaner, which is the hardest and messiest part of the job, tightned the cover down down, and so far no leaks.
Right stuff is expensive, but if it works, AND it can replace the gasket, its worth every penny.
I'm thinking the only problem is later, when I have to clean and scrape it all off  :clueless:
« Last Edit: January 14, 2011 - 05:38:24 PM by tommyg29 »
Offline tommyg29
« Reply #6 on: January 14, 2011 - 06:17:51 PM »
while here I thought I'd toss in a few more pictures.
Any comments about my bottom end?
I do see a little scuffing on a cylinder wall but I guess its normal?
and my dipstick only protrudes about an inch. Hope thats ok? Guess it depends on where the marks are. I'll check that, but should oil fill the pan to the top?
« Last Edit: January 14, 2011 - 06:20:32 PM by tommyg29 »
Offline beekppr
« Reply #7 on: January 14, 2011 - 09:22:24 PM »
I can see that it was rebuilt and they added the double roller chain.
Did they balance the engine at that time? The connecting rod tabs on the caps look like they were not touched but the crank counterweights looks like they were.
Offline Cooter
    • christinecarclub.com
« Reply #8 on: January 14, 2011 - 09:39:28 PM »
Did the engine have a windage tray in it? If it was a true SIX PACK engine, it shoulda came with the tray and the double roller chain stock. If not, now is the time to add one for a few extra ponies....I can't tell if they are SP rods or not from the pick as I would need to see them from the side..The rods may or may not have had to be touched when balancing the bottom end.I've seen where the material was removed from the bottoms of the pistons instead..
« Last Edit: January 14, 2011 - 09:42:38 PM by Cooter »
Offline beekppr
« Reply #9 on: January 14, 2011 - 10:06:57 PM »
Interesting about taking it off the pistons. And I didnt know that they put double rollers in the six pack motors. I learn stuff in here everyday!
Offline mopar12372
    • mopartech
« Reply #10 on: January 14, 2011 - 10:13:50 PM »
everything looks good from here :2thumbs:
RESTO PICTURES
Offline tommyg29
« Reply #11 on: January 14, 2011 - 10:17:49 PM »
Its not a true six pack engine, but kinda a mongrel put together by the prior owner 4000 miles and 7 years ago.
ENGINE BLOCK - '74 440 HP
+ .030 Bore - stock 3.75 stroke (446ci)
Stock cast crank and stock LY rods
TRW forged flat tops, Federal bearings, stock       replacement rings
CARBS - Factory '70 six pack 4sp vacuum, jetted and tuned
INTAKE - Factory '70 iron 6bbl that was port matched
HEADS - '66 516 casting closed chamber
Heads have 2.08/1.74 stainless performance valves, pocket ported and cleaned
245cfm @.550 intake / 175cfm @ .550 exhaust
Final compression of 10.5:1
CAM - Crane hydraulic H-302-2, 302°, .504 lift, 232° @ .050 intake, 312°, .528 lift, 242° @ .050 exhaust
Offline 72cudamaan
« Reply #12 on: January 14, 2011 - 11:09:56 PM »
You can see where the bottom of the rods were ground down to remove weight.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Challenger6pak
« Reply #13 on: January 15, 2011 - 12:25:11 AM »
Tommy,
  If you leave the motor tie down chain where it is it most likely won't work.  It is good at the frame.  The hole you have it mounted in on the block won't handle the impact if your mount breaks.  The boss in the block will break.  I would suggest moving the chain to the block motor mount boss.  Bolt it on with a motor mount bolt.  You will need to get a longer grade 8 bolt to do this.
« Reply #14 on: January 15, 2011 - 09:06:15 AM »
the full level should be below the crank counter weights , basically to the bottom of the windage tray , your dipstick looks too short to me .
 Light scuffing is normal in the cylinders , scoring is not . probably got too warm at some point
 I use a steel strap across the mount to secure it instead of a chain , that way there is no windup before it hits the end of the chain
