Author Topic: Goodysgotacuda - Wheel and tire specs  (Read 27834 times)
Offline GoodysGotaCuda
Re: Goodysgotacuda - Wheel and tire specs
« Reply #30 on: November 24, 2013 - 02:55:12 PM »
 :useless:
Brad, what did you end up doing, did you go 17 or 18's???
Mike, do you think it "might" be possible to squeeze the rear rims out to 9 1/2 or even 10" on a 295??? or would that cause to much rubbing, Nice combo's guys
Greg
I don't think I'd dare with a wider wheel than where it is now. At least not with moving the perches or something in conjunction with the wider wheel.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline crash340
« Reply #31 on: November 24, 2013 - 03:06:07 PM »
Thanks Mike, I dont want to do that or any fender lip mods as the car is an original all matching car as it came off the factory floor so I want to be able to revert it back maybe one day. I guess I could get another 8 3/4 housing, shelve the original as just that, original. then move springs in board but a lot of work just to go wider when its probably not needed.
Thanks again Mike, appeciate it
Greg
Greg
73 Cuda
Brisbane, Australia
Offline LEMOOREACE
  • I was a llama, but I have since evolved.
« Reply #32 on: November 24, 2013 - 08:28:26 PM »
Just an FYI. I did change to 1/2 inch spacers rather than the 3/4 inch.  I was rubbing the fenders a bit out back.  Still left me enough space on the inside.  I am also on the Hotchkis springs now which dropped her about an inch.   Fender lips are not rolled.
Thanks again Goody for the inspiration!!
« Last Edit: November 24, 2013 - 08:35:16 PM by LEMOOREACE »
