Exhaust Tips:Expandable
Author Topic: Exhaust Tips:Expandable  (Read 3931 times)
Offline 73yellowfish
« on: January 14, 2011 - 10:39:44 AM »
Here's the problem with buying parts and stockpiling them.. sometimes, they don't always match up...
I've had this cuda addiction for about 6 years now, and during the complete reconstruction of it, I would buy parts at shows, and store them away for better days..
I bought my chrome tips a few years ago.. they are 2" dia.
I bought my tti exhaust system.. it's at 2.5" dia.
 :banghead:
Do i
·try to expand the tips to 2.5
·weld a reducer to the tips
·buy new tips... please say no..
·something else?
 :1zhelp:
'73 cuda
(O [       ]{|||}[       ] O)
Offline Skunkworks Challenger
  • Mopars forever!
Re: Exhaust Tips:Expandable
« Reply #1 on: January 14, 2011 - 11:06:21 AM »
I have the exact same story!  Sorry, I'm not offering an answer, just wanting one.  I need to dig out my tips and see if I can expand them.  Will watch with baited breath! :clueless: PK
The Brewmaster
Offline GoodysGotaCuda
« Reply #2 on: January 14, 2011 - 11:12:55 AM »
I'd try to slide another pipe over the tip and run it
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline wally426ci
    • maryland mopars
« Reply #3 on: January 14, 2011 - 11:21:40 AM »
Yep. you can get adapters at most parts stores.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline dutch
« Reply #4 on: January 14, 2011 - 11:39:17 AM »
if you do that, you might as well use a 2"exhaust system...
I`d cut off the 2"pipe and weld a 2.5"on  :2cents:
*** Bart ***
« Reply #5 on: January 14, 2011 - 12:03:38 PM »
would the reduction in size at the end of the system have that big of effect on the overall performace?
If anything, I would buy the new tips, over the whole system, but would prefer to make this work...unless an issue you could think of would come up that would really be detrimental to the car...
if that makes any sense..
'73 cuda
(O [       ]{|||}[       ] O)
« Reply #6 on: January 14, 2011 - 12:15:03 PM »
I believe you will be fine , the restriction is only 2" long , I read in an exhaust engineering book that reducing the pipes at the rear as the air cools can help performance & reduce drone , you could expand them to slide inside the 2.5 " pipe or worst case use an adapter
« Reply #7 on: January 14, 2011 - 01:29:23 PM »
actually increase preformace? hmm interesting...
after speaking with a knowledgable mopar guy, another facter he proposed would be that cuda's exhaust comes in at an angle and the modifications that i mentioned would throw off how the tips come through the valance.Unlike the challenger which goes straight in... true?
I think right now, I might buck up and get the new tips from TTI and sell the 2" ones...any buyers?
who knows, my opinion might change again in an hour... :clueless:
'73 cuda
(O [       ]{|||}[       ] O)
Offline 73EStroker
« Reply #8 on: January 14, 2011 - 02:11:43 PM »
If you purchased ones made of stainless steel then forget the expanding idea. It will break in the expander. Mine were 2-1/2" from PG Classics and needed a tiny bit more expansion to fit the 2-1/2" pipe and the guy who did them said it was touch and go. You will not get 1/2" more from them.
Barry (Salmon Arm)
Offline Katfish
  • 70 Challenger
« Reply #9 on: January 14, 2011 - 04:25:31 PM »
I'm in the same boat with my Challenger tips.  You can get a 2-2.5" adapter for cheap.
I have a 2" system now and will be eventually upgrading to the TTI sysytem.
I went ahead and bought some tips that are 2.5".  I'd look around you can do much better than TTI on price.
They wanted $400 for the Challenger tips, I got some for $150.
Make sure you get the right size, some are OD and others are ID.
  • Mopars forever!
« Reply #10 on: January 16, 2011 - 12:13:02 PM »
Here is how I plan to "expand" my 2" tips.  Use either a 3x2.5" adapter or a piece of 2.5" pipe and squeeze it in a vice to a rectangular or oval shape.  Place it over the 2" extension and mark where it makes contact.  Cut out the 2" extension and weld in the rectangular end, making sure to have the correct overall length.   PK
The Brewmaster
Offline Katfish
  • 70 Challenger
« Reply #11 on: January 16, 2011 - 02:17:03 PM »
Those look like the factory sheet metal tips, not SS?
I thought about doing something similiar, but unless you can weld it yourself it's a lot of work to go through.
Sell the 2" and get the 2.5" done right.
« Reply #12 on: January 16, 2011 - 08:13:23 PM »
Unfortunately that looks like the route i am going to go..again.. the angle of the cuda's tip worry me...
any body want to buy my 2in tips?
'73 cuda
(O [       ]{|||}[       ] O)
