Author Topic: starter relay pic  (Read 3367 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
starter relay pic
« on: January 17, 2011 - 02:48:51 PM »
Hello! I am looking for a pic of a starter relay on a car with the wires connected with a manual transmission. I need to know which one I need to ground for the clutch and I want to make sure where the other wires go.
Offline GoodysGotaCuda
Re: starter relay pic
« Reply #1 on: January 17, 2011 - 03:29:17 PM »
I dont have a pic, but it should be a straight male spade connector on the relay. There will be a large stud, small bolt, "ign" spade and the ground for the relay for either a neutral safety switch (auto) or clutch switch (manual). I believe it will be on the left side of the relay looking down at it from the drivers fender.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #2 on: January 17, 2011 - 06:43:55 PM »
on mine if you have the relay in your hand looking at the face of it the wire goes on the top left spade,,at least mine does
72rtchallenger
what happens in the garage
stays in the garage
« Reply #3 on: January 17, 2011 - 09:19:07 PM »
Cool! Thanks! I'll take a pic when I am finished to confirm. So all I need to do is run the wire with a female spade connector from the starter relay to the inner fender somewhere????
  • 72 to 70 clone
    • cardomain
« Reply #4 on: January 18, 2011 - 06:29:38 AM »
runs to the clutch switch at the pedal,,and the relay will have a g stamped on it to confirm were it goes on the relay if you can get close enough to read it
72rtchallenger
stays in the garage
« Reply #5 on: January 18, 2011 - 08:01:40 AM »
I'm actually going to bypass it because I don't have the clutch switch. I'm not sure why they are so expensive.
« Reply #6 on: January 18, 2011 - 08:21:45 AM »
 :droolingbounce:
Just be sure you are the only one that will be starting it!
1976 Dodge Warlock
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #7 on: January 18, 2011 - 08:44:12 AM »
Brewers is the only ones reconditioning them, No one else . you could rig up other style of switch. it is just a grounding issue
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #8 on: January 18, 2011 - 09:19:16 AM »
I will eventually set this up, but I was going to ground it for now so I can get it started. That would be my luck to hit the key and run into something or someone.
« Reply #9 on: January 18, 2011 - 06:47:23 PM »
Here is the Pic of mine. I take it the top left spade is the ground for the clutch? Does the yellow connector on the headlight harness connect to the top right spade? The gray wire is connected tot he starter. Is that correct?
« Reply #10 on: January 18, 2011 - 07:20:12 PM »
Can you see the G and IGN, that relay is upside down too, i think
1976 Dodge Warlock
Offline UKcuda
  • Tell them I'm on my way
« Reply #11 on: January 20, 2011 - 03:57:18 AM »
Most cars in the UK are manual trans. and I've never seen one with a clutch safety switch.  You just get in the habit of checking it's in neutral, and it's not too easy to start a manual in gear anyway.
'72 'cuda
Offline willard
    • 1970 Challenger R/T
« Reply #12 on: January 20, 2011 - 09:34:26 AM »
99% of european cars dont have it, so from the day 1 everyone knows to start the car with the clutch depressed. of course **** happens  :grinyes:
1970 383 R/T SE
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #13 on: January 20, 2011 - 10:42:08 AM »
When I worked at aa car dealer years ago, there was a used car trade in that had a manual tranmission and a remote starter installed.  :nono:
The car wash kid hit the auto start button on the remote, the car was in gear and nailed the car in front of it.  :faint:  Good thing no one got hurt.
« Reply #14 on: January 22, 2011 - 02:48:45 PM »
