Author Topic: Resto-Rick Pistol-grip Auto shifter install ...  (Read 46174 times)
Offline walkAbout
Re: Resto-Rick Pistol-grip Auto shifter install ...
« Reply #30 on: January 21, 2012 - 05:42:34 PM »
What's it doing? Has it started to unscrew and then stopped? or simply won't unscrew at all?
Simply won't unscrew at all... I can screw and screw, even not pull it off, but I think I pulled the whole rod. I grabbed the rod that goes down at the end, and hold it with a pincer. Nothing. Now the end of the rod is bent and the trigger won't trigger right. :shock: The metal knob seems to be rusted to the rod. So I will not try it again and will remove it with a dremel.
CU
walkAbout
« Reply #31 on: January 21, 2012 - 06:35:43 PM »
Somebody knows if this trigger button is stock? I can't get it off and will destroy it.
CU
walkAbout
No it's not stock, looks like it's metal and starting to rust? Further down the knob there should be a set screw. It should just pull off then you remove that set screw?
« Last Edit: January 21, 2012 - 06:37:43 PM by brads70 »
Offline TreeFrog
    • TreeFrog
« Reply #32 on: January 21, 2012 - 08:52:12 PM »
How do I say this without sounding like an idiot ...
A couple of members let me ....
Wow ... guess I will have to go for it...
try out their shifters at Carlisle ...
I tried both trigger styles and the most comfortable was the Gunslinger
I like the looks of the Auto better esp the cant of the grip.
as much as the push-down style looks "more real" I just don't like to push down to shift.
Who here has the auto with the boot that looked like a 4-speed (that was pretty good looking in person)
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
« Reply #33 on: January 21, 2012 - 09:14:10 PM »
If you look in this post I have a picture of someone elses  with the 4 speed boot on it. Looks nice!
http://www.cuda-challenger.com/cc/index.php?topic=71514.msg729654#msg729654
Offline walkAbout
« Reply #34 on: January 22, 2012 - 10:38:42 AM »
Yes, it's metal and yes I completely removed the allen set screw. I've set a screwdriver under the metal until it bent the screwdriver. It must be screwed not just pushed and my guess the thread rusted together with the metal knob. I will use a dremel to remove it...
CU
walkAbout
Offline walkAbout
« Reply #35 on: January 23, 2012 - 04:03:31 PM »
... and I'm starting to think this metal knob is self made by the resto guys. If you look on top, the circle is not right in the middle (hope you know what I mean). Furthermore I think they glued it to the threaded rod. And there is not the right spring under the metal trigger. Let's see once I have it off.
CU
walkAbout
« Reply #36 on: January 23, 2012 - 06:30:54 PM »
CU
walkAbout
Time for some vise grips maybe? It's not stock so who cares really if you wreck it. I'm guessing they made a hole under it just the right size or smaller than the shifter needs and just hammered it on.
Offline walkAbout
« Reply #37 on: January 24, 2012 - 03:57:25 PM »
Yeah, finally I got some advise today from quapman how to remove the whole center shaft. My thoughts are now:
When removing the small cross pin near the bottom of the shaft it should be possible to pull out the center shaft with my unremovable metal trigger button. Then I can take a closer look, what is wrong with it and I can even remove the shifter plate and woodgrain knob, which is still on and disturbs me.
And yes, then I will wreck it and wait for the Auto-Grip.  :bananasmi
Will take a short look right now.
I'm writing this here, cause maybe one day someone needs the information too.
CU
walkAbout
Offline walkAbout
« Reply #38 on: January 25, 2012 - 04:35:37 PM »
Hi peeps,
mystery solved. Finally.
I removed the rubber (not plastic) insert (where the upper rod connects), found the cross pin, removed it and I'm happy now. Nothing is wrecked, the self-made button was glued and I could remove it easy when the rod was out.
The attachment shows the rod which is bent, but not down at the end, as I guessed first, but on the top. I think it should be straight, isn't it?
I hope they did not shorten the rod.
Any ideas out there? I have to straighten it, right?
CU
walkAbout
Offline vert
  • Looking good, Billy Ray! Feeling good, Louis!
« Reply #39 on: January 21, 2015 - 04:39:35 PM »
Latecomer to this thread.  You can straighten this rod by putting it in a vise, squeeze, loosen, rotate a little, repeat...
Biggest thing I recommend here is BE&A  parts has the chrome bezel with lense, and the black plastic slider for the gear indicator.
71 Barracuda | Hemi idling | Hemi Dyno pull
Offline 734406pk
  • Andy
« Reply #40 on: January 24, 2015 - 11:10:26 PM »
Well I don't know where I am on this thread but that pistol grip shifter handle looks awsome. I have to get one!
Offline Code3
« Reply #41 on: February 05, 2015 - 03:31:44 PM »
It looks like on some of the consoles there is a thin piece of cork or rope caulk on top of the shifter bezel and underneath the console woodgrain top plate.
I scraped off some black sticky stuff which was under the top plate on mine but I don't know what to replace it with.
Does anyone know what I should use or does anyone care?  :blah:
Offline tommyg29
« Reply #42 on: January 10, 2016 - 09:59:50 PM »
Old thread, I know, but I found it and really liked some ideas in here, so I did the same with my 72 road runner. Ordered from resto rick, and the sleeve didnt fit. It was too tight, and wouldnt slide up and down, so after "modifying" it I worked around that, and then found the road runner 4 speed rubber boot wouldnt work. Its not flexible enough, so after looking carefully at Brads picture, I realized that isnt a road runner boot. I believe its from a 2000-2004 jeep, so I ordered one for $24 and it works really well. Im really happy with it. Thanks  to all for all the great ideas.
Here's the end result, courtesy of Santa Claus.
Offline 734406pk
  • Andy
« Reply #43 on: January 11, 2016 - 12:23:10 AM »
That looks really good! :thumbsup:
Offline 70chall440
« Reply #44 on: January 11, 2016 - 12:33:30 AM »
looks good.
Current Mopar
Past Mopars
