Author Topic: Exploded view of Clutch/Brake Pedal Assembly  (Read 3224 times)
Offline 7Dcuda
« on: January 22, 2011 - 09:28:28 AM »
Does anybody have or know where I could find an exploded art view of the clutch/brake pedal assy. with mounts?
Re: Exploded view of Clutch/Brake Pedal Assembly
« Reply #1 on: January 22, 2011 - 09:43:02 AM »
Offline 7Dcuda
« Reply #2 on: January 22, 2011 - 09:53:57 AM »
Awesome!!!  Exactly what I needed...thanks Topcat!!
Offline 7Dcuda
« Reply #3 on: January 22, 2011 - 09:57:50 AM »
After reviewing the pic...it doesnt show the clutch pedal which is mainly what I need the pic for.
Offline 7Dcuda
« Reply #4 on: January 22, 2011 - 10:04:39 AM »
Mainly what I need that that pic doesnt show is how the clutch pedal, spring, and clutch switch mount.  Any help would be appreciated.
Offline femtnmax
« Reply #5 on: January 22, 2011 - 08:22:58 PM »
Does this help?
Phil
Offline 7Dcuda
« Reply #6 on: January 23, 2011 - 08:20:26 AM »
Does this help?
Yes, that helps alot.... appreciate it femtnmax.
Only one thing left.....how does the short spring pin attach? (cant be seen in this pic)    Is that the left side of it sticking out of the top back corner of the triangular plate?  If so, where does the other side mount?
Offline femtnmax
« Reply #7 on: January 23, 2011 - 08:09:45 PM »
Are you talking about the black pin shown in photo with flats cut into the end?  Looks to be the same pin that the brake pedal pivots on.  The triangular bracket is a seperate piece as shown in Topcat's drawing.
Topcats drawing also shows the pin with flats on the end.  There is a nut on the end opposite to the end with the flats.
Does this pic help?  Maybe zoom in on it.
Phil
Offline 7Dcuda
« Reply #8 on: January 23, 2011 - 08:40:38 PM »
No, wrong pin.  I'm talking about the short pin that the end of the spring nearest the firewall attaches to.  I see now in the photo.....thanks again femtnmax!
