Author Topic: fuel pump question  (Read 1192 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
fuel pump question
« on: January 23, 2011 - 08:25:14 AM »
This is a dumb question, but what connection goes to the carburetor? The threaded connector or the slip on connector?
Offline LAA66
Re: fuel pump question
« Reply #1 on: January 23, 2011 - 11:10:13 AM »
 The threaded end goes to the carb. You can use a section of 5/16" or 3/8" preflared brakeline and bend it to fit the application.
« Reply #2 on: January 23, 2011 - 11:34:40 AM »
Cool! Thanks! I am guessing I shouldn't use rubber fuel line? I have the connectors that thread into the carb and the feul pump that the fuel line slips on. Or should I use straight brake line and no rubber gas line?
« Reply #3 on: January 24, 2011 - 05:10:10 AM »
from the factory there is a rubber line approx 8" from the line on the frame to the fuel pump on the engine to allow movement & 2 short pieces of rubber to accomadate the fuel filter on the way up to the carb . The filter should NEVER be installed before the fuel pump
« Reply #4 on: January 24, 2011 - 08:00:20 AM »
Cool! Thanks!
Offline bandt
« Reply #5 on: January 24, 2011 - 11:41:24 AM »
Sorry if this is kind of a hijack but why is that Neil?
« Reply #6 on: January 24, 2011 - 02:19:52 PM »
No Biggie! I was wondering the same thing.
Offline Aussie Challenger
« Reply #7 on: January 28, 2011 - 02:59:42 PM »
:iagree:  If filter is installed before the pump when it starts to block/stop dirt it will restrict flow quickly because there is only atmospheric pressure pushing fuel through it, plus the filter itself can cause a restriction as well. Whereas if on pressure side it then has full pump pressure to over come restrictions.   :2thumbs:
« Reply #8 on: January 28, 2011 - 03:42:36 PM »
 :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs: :2thumbs:
« Reply #9 on: January 28, 2011 - 08:04:32 PM »
Looks like I gotta move my fuel filter. :banghead:
Thanks for the info CP, Aussie  :2thumbs:
« Reply #10 on: January 30, 2011 - 03:18:24 PM »
Exactly as Aus said , you have a prefilter in the fuel tank & anything that can get through that will nto hurt the fuel pump , you always want the pump to push fuel through the filter , it is far more effective than trying to pull through a filter ! If you like being stranded with fuel starvation problems just put the filter on the suction side instead of the pressure side !!
Offline usraptr
« Reply #11 on: January 30, 2011 - 04:14:06 PM »
Another reason you don't want to run all rubber gas line is the possibility of vapor lock.  Back in the day, I broke the metal fuel line my my wife's '67 Cougar with a 390.  I replaced it with rubber gas line and had problems with vapor lock on hot days.  Apparently the rubber gas line doesn't keep the fuel as cool as the metal lines do.  FYI.
(Edited 8-1-17)
Offline LAA66
« Reply #12 on: February 02, 2011 - 10:29:30 PM »
 As a  :2cents: note; those autopart store pumps don't last very long. Especially if the car sits for extended peroids of time. Just replaced one with less then 2000 miles on it. Luckly it happened at home base so toeing wasn't necessary  ;).
