Author Topic: fan pulley on conversion to sanden compressor  (Read 1243 times)
Offline cmesa
« on: January 24, 2011 - 06:03:33 PM »
I have tried to run a belt that ran thru the alternator-fan-power steering and  crank  but cannot tighten it. I have a single fan pulley. I have a  340 1972 Barracuda  factory air car.
Offline the_engineers
Re: fan pulley on conversion to sanden compressor
« Reply #1 on: January 24, 2011 - 06:12:51 PM »
You need a double-groove fan pulley.  With all of those accessories on one belt, you can't be getting more than 45* of engagement on your water pump or crank...guaranteed to slip or overheat, whichever comes first.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline cmesa
« Reply #2 on: January 24, 2011 - 07:06:20 PM »
thank you
were can i get a double pulley?
Offline Katfish
  • 70 Challenger
« Reply #3 on: January 24, 2011 - 08:33:17 PM »
Try Mancini
http://chucker54.stores.yahoo.net/strepu.html
Got any more info on what you're doing?  I'm looking to convert to a Sanden compressor.
« Reply #4 on: January 24, 2011 - 09:52:30 PM »
Brooks
1971 'Cuda 360
Offline beekppr
    • Dodge Challenger Project
« Reply #5 on: January 25, 2011 - 11:33:25 PM »
Bouchillon performance makes some nice stuff too. Not sure on exact spelling though.
« Reply #6 on: January 26, 2011 - 01:00:50 AM »
I got a dual pulley for the water pump...15 bucks n shipping :dunno:
Offline ShelbyDogg
« Reply #7 on: January 30, 2011 - 06:48:28 PM »
I voted "tech"
I have 2 small block A/C cars. I can send some pics up when I get home, if you need to see how the belts run.  If I remember correctly, the alternator goes to the compressor then to the crank. The power steering and the fan are on the same belt.
 The water pump has a single pulley.
Offline ShelbyDogg
« Reply #8 on: February 04, 2011 - 10:55:12 PM »
Here you go.  Small block A/C pulleys:
Offline nqkjw
« Reply #9 on: February 05, 2011 - 04:04:39 AM »
Mate,I understand the problems you're having.
I've done a Sanden conversion to both my BB challenger and SB Dart.
Burnouts are cool but Traction is the Action
Offline ShelbyDogg
« Reply #10 on: February 21, 2011 - 10:46:12 AM »
You just have to do a little Fabrication or modification of your brackets and everything can fit.  I also have a friend with a shaker on a hemi, that cut off the extra mounting tabs so everything looks fatory.  Another friend adapted one to his small block too.  You have to start with the A/C pulleys and brackets before proceeding.
Here are a couple of pics of cars I've seen.
