cabs can get you close - yes, and no -
carbs can get you close for that moment, yes, if you are driving in drastic temperature, or elevation changes then no it will not be close any more since the carb is set at one point in time, - EFI will adjust several thousand times per second taking into account, air temp, pressure ( elevation changes) barometric changes, - the list goes on and on!
