Author Topic: Hood Insert Stripped  (Read 4305 times)
Offline the_engineers
« on: January 24, 2011 - 11:38:02 PM »
One of the threaded holes in my scoop is stripped and the insert consistently works itself loose.  I thought about using the thread-riveter on it, but am hoping for other options, first.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline beekppr
    • Dodge Challenger Project
Re: Hood Insert Stripped
« Reply #1 on: January 24, 2011 - 11:50:18 PM »
What's a thread riveter?
Why wouldn't a helicoil work in that situation? Or is the insert your talking about a helicoil which is no longer staying put?
« Reply #2 on: January 25, 2011 - 11:37:44 AM »
A thread riveter, or thread setter, allows you to crimp a threaded insert into thin or sheet material (metal, plastic, etc.).  Sizes vary up to 5/16", based on the model you purchase.  I bought a Marson on eBay for about $60 and I've used it hundreds of times in the last 6 years.
http://www.sjdiscounttools.com/mar39202.html.
I hadn't thought about heli-coil...worth a shot!
Brooks
1971 'Cuda 360
« Reply #3 on: January 25, 2011 - 12:00:25 PM »
What about using loctite and a stud , instead of a bolt? Red loctite is permanent.
Can it be drilled and tapped a little deeper to get some more good thread engagement first?
Offline dutch
« Reply #4 on: January 25, 2011 - 12:09:19 PM »
those inserts are aluminium right?   why don`t you weld up the hole and drill a new one?
*** Bart ***
« Reply #5 on: January 25, 2011 - 04:00:38 PM »
I think these vary somewhat by year-to-year.  The black insert is held to the body-colored scoop by two screws.  The scoop itself is already painted, so I have concerns about welding discoloring the paint.  I think I'm going to try the helicoil first and see where that puts me.
Anyone got a picture of the 'Cuda scoop itself, without the insert attached?  Might simplify this conversation somewhat.
Brooks
1971 'Cuda 360
Offline JayBee
« Reply #6 on: January 25, 2011 - 07:01:52 PM »
I had the exact same problem. I ended up removing the scoop from the hood and putting a nut on the backside. The threads are actually inside a rubber housing. The rubber eventually rots and breaks off with the thread in it. The pic of the left scoop is a good thread mount, the right one shows one broke off.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline RUSTY Cuda
  • One big step foward!
« Reply #7 on: January 25, 2011 - 08:18:15 PM »
I think rt spec. sells new rubberized nuts, I bought them somewhere, maybe ck with mopar dave? Rich.
« Reply #8 on: January 25, 2011 - 09:41:09 PM »
Offline dutch
« Reply #9 on: January 26, 2011 - 01:01:10 PM »
John, your 70 should have inserts with studs.  The 70 scoops just have holes in them.  :2thumbs:
*** Bart ***
« Reply #10 on: January 26, 2011 - 01:46:20 PM »
I think you meant 71's just have holes...
Brooks
1971 'Cuda 360
Offline dutch
« Reply #11 on: January 26, 2011 - 04:33:13 PM »
 :clueless:   ot sure if we mean the same thing here...
here`s a pic of a 70 scoop. It has holes with no thread in them. The inserts have studs on them and are helt in place with speednuts. sorry for the off-topic.
*** Bart ***
« Reply #12 on: January 26, 2011 - 05:32:22 PM »
Later 71-74 scoop.  The through holes are for the locating pins.  The threaded holes are where screws go through the insert and into the scoop body, holding the insert in place.  The later inserts can be removed with the scoop still on the car.
Brooks
1971 'Cuda 360
Offline JayBee
« Reply #13 on: January 26, 2011 - 05:45:13 PM »
Yes Bart. I have a '71 & up hood on the car. I realized it was wrong after looking at yours in your resto thread. There was a correct '70 hood with correct scoops for sale at last years Nat's but I had no way of getting it home.
Like a well nut? :dunno:
http://www.spaenaur.com/pdf/sectionC/C147.pdf
Brad, those look promising.
John
2014 Toyota Avalon
Offline JayBee
« Reply #14 on: February 15, 2011 - 06:08:31 PM »
Well, I pulled the trigger on Brad's well nut suggestion and they look bang on. They slip right into the exsisting scoop's hole and with a little pressure on the insert you can thread the screw in easily. Unfortunately, I had to buy in bulk, maybe some specialty "nut & bolt" place sells them separately.
PIC#1 - Well nut.
PIC#2 - New one installed on my spare scoop.
PIC3# - Original dry rotted and cracked one.
John
2014 Toyota Avalon
