Author Topic: What's this wire do?  (Read 1372 times)
Offline Milkmann
« on: January 25, 2011 - 08:11:08 AM »
Trying to make my gauges work on my 1974 Challenger Rallye dash, going to start with a new voltage limiter. Ordered one from Dash Worx, got the dash panel loose, find the limiter AWOL. P.O. replaced it with a small resistor setup but at least the wires going to it are labeled.
My question is, I see a wire that has been clipped in the general area. It is a light gray wire with a black tracer that comes out of the wiring harness between the wires that go to the turn signal indicator lights.
Anyone know what this wire is for? I don't think even Chrysler would have had an extra wire sticking out for no good reason. It is just clipped off, not capped over or anything. I didn't see anyhting near there that looked like a good destination, either.
Re: What's this wire do?
« Reply #1 on: January 25, 2011 - 11:28:44 AM »
I can think of two gray wires, but I don't recall either having a black tracer.    :dunno:
One is the power to the clock, the other is the signal for the tach...It comes from the "-" side of the coil.
Offline dutch
« Reply #2 on: January 25, 2011 - 12:11:51 PM »
oil pressure uses a gray one too?
*** Bart ***
Offline HemiOrange70
« Reply #3 on: January 25, 2011 - 12:58:30 PM »
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: January 25, 2011 - 02:41:05 PM »
tach or Oil both use grey wires. grey/red is tach, grey/black is oil gauge
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline Milkmann
« Reply #5 on: January 25, 2011 - 06:29:55 PM »
Thanks Mopardave-oil gauge not working(along with temp gauge)is why I started this escapade.
I'll check that out.
I had printed a diagram off Mymopar, but it didn't list a gray/black wire that I could find.
Offline Milkmann
« Reply #6 on: January 27, 2011 - 08:17:01 PM »
My voltage limiter from Dash Worx showed up today(already!), I had a few minutes so I stuck it in. While I was fooling around with the dash, I figured out where my cut wire came from. It is the signal wire for the tach, P.O. ran new wires to the quart-can size Mallory coil mounted on the right fender. He did a half-decent job and the tach works most of the time, so I'll probably just leave it as-is.
I did come on here and do a search for "tachometer", put my mind at ease that 12V is perfectly fine for the tach. Checking and cleaning the connections is on the short list of things to do.
