Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Sound Deadner
« previous
next »
Print
Pages: [
1
Author
Topic: Sound Deadner (Read 1356 times)
challenger_73
Jr. Member
Sound Deadner
on:
January 25, 2011 - 09:33:38 AM »
Does anyone have a picture of sound deadener that they put on the ceiling of their car (Challenger)? I'm just trying to make sure that I don't put any where it will interfere with the headliner, Bows, light or seat belt clips.
Tony=challenger_73
Logged
burdar
Sr. Resident
Re: Sound Deadner
Reply #1 on:
January 25, 2011 - 10:01:35 AM »
You can put insulation on the roof skin but not on the inner braces. The dome light wiring clips onto the center brace...the light itself screws to the same brace.
Logged
challenger_73
Jr. Member
Re: Sound Deadner
Reply #2 on:
January 25, 2011 - 04:25:46 PM »
What about the b-pillar area?
challenger_73
Logged
burdar
Sr. Resident
Re: Sound Deadner
Reply #3 on:
January 25, 2011 - 04:46:52 PM »
Nothing was there from the factory. Earlier cars used sail boards in that area so there is room for some thin DynaMat type stuff if you want to put something there. Your 73 didn't use a sail board though. It's up to you. The dome light wiring does run into that area so you'd have to leave a spot open to run that.
Logged
UKcuda
Full Member
Tell them I'm on my way
Re: Sound Deadner
Reply #4 on:
January 27, 2011 - 05:21:24 AM »
Quote from: challenger_73 on January 25, 2011 - 04:25:46 PM
challenger_73
no photos but I just put mine on the roof between the braces.
On the sail pillars I didn't put any in but I did close them off from the trunk area using expanding foam. I figured that a lot of noise comes in from the trunk area and rather than treat that whole area I decided to just isolate it from the passenger area. In addition to closing off the sail panel voids I also stuck some fibre board in behind the rear seat back and applied sound deadener across that whole area and along the speaker shelf. It worked pretty good.
Logged
'72 'cuda
ShelbyDogg
Sr. Resident
Re: Sound Deadner
Reply #5 on:
January 27, 2011 - 10:36:54 PM »
I put 2 layers of that carpet padding that looks like multi-colored shredded padding glued back together over my headliner. Once the headliner is stretched tight, you dont see anything. Helps keep the car cool with the A/C on.
Logged
EbodyPro572
"Always restore, NEVER discard!"
Jr. Member
Re: Sound Deadner
Reply #6 on:
January 30, 2011 - 08:21:33 PM »
'Second Skin' sells stuff for the entire interior. Think they have something you can use on the roof panel. You might want to check them out at secondskinaudio.com
Logged
'ALWAYS Restore.....NEVER Discard'
73 Challenger; 04 Rumble Bee (Yello, of course); 01 Vehicross (Yello, of course, too); 90 Allante' (not Yello, just red); 79 MGB-V8; 68 Century Resorter;
73 Marlin Ski (468" Olds) Jet Boat; 06 Harley Fat Boy CVO; 73 Yamaha Golf Cart (Yello, of course); 07 Sears Garden Tractor
500Stroker
Full Member
Re: Sound Deadner
Reply #7 on:
January 30, 2011 - 10:18:23 PM »
I used this foil backed jute padding I found on JC Whitney. Used 3m spray adhesive to attach to the ceiling. It did not interfere with the bows or headliner.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Sound Deadner
