just FYI here, but on SOME of the newer starters, I have had to grind off the top of the stud where the POS casble attaches...On a BB 440, most studs poke up into the rear freeze plug area and ground out...Never had to remove any of the plastic as the first time you go for any kind of warranty and have modded the starter, you WILL BE turned down...Most of mine come from junkyards...
