Author Topic: connection on mini starter question?  (Read 4691 times)
Offline Barracudadan
Re: connection on mini starter question?
« Reply #15 on: January 30, 2011 - 10:08:09 AM »
Thanks for the idea Tom but I can`t see from the picture what you did down at the starter?Did you find the right type of connector for the solenoid or just a spade type connector and shrink tube over it? What is that hiding under the battery an amp for the stereo or ignition setup? Cool hiding spot!
Offline 422STROKER
  • Member Since 6/3/06
« Reply #16 on: January 30, 2011 - 10:26:55 AM »
I think I used a crimp butt splice with the proper connector, but give me a few minutes to head down to the garage.  I had to swap the starter in after I had the car all together.
Tom
Ignition set up and a fused distribution block along with some headlight/foglight relays under there.
Tom
Offline 422STROKER
« Reply #17 on: January 30, 2011 - 10:35:01 AM »
Wow it's cold down there in the garage.LOL
I used spade connectors and a sleeve of heat shrink tubing to cover the connection.
That connector should be available at NAPA or Carquest as a replacement part.
I haven't had any issues with corrosion on the wiring using this method, been together for 4+years and looks new under the hood for the most part.  Drive it in all weather(except snow) and is holding up well. FWIW.
Tom :2thumbs:
Tom
« Reply #18 on: January 30, 2011 - 03:31:59 PM »
in the past I have just flipped over the end of the factory cable , tweaked the connectors a little & it hooks up fine , you can also cut between the 2 wires & attach them seperatly
